![]() | Home > Technical (L322) > Air con fan fire |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
was it full fat milk......sorry i couldnt resist |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 ![]() ![]() ![]() |
Nah semi skimmed had to put twice as much on, I agree very lucky . Anyone know how to remove the electric fan in front of rad please , looks like it may come off through the front ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
RAVE says grille off, front bumper (completely, including armature) off to get it out |
Thanks for info , will make a start tomorrow , just need to source a new fan now |
2 or 3 here http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
Thanks joe90 , replacement fan fitted today , fingers crossed all ok. Bumper was an adventure to remove / refit but managed to change a lot of dodgy fixings in the process . Found a bit more info on bmw sites , not a common fault but has happened on a few (it's a bmw fan) . Fire extinguisher now kept in the boot. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Since I saw a car go up in flames, in less than a minute, I've had an extinguisher in the boot. They are so cheap, it's silly not to. Mines strapped to the parcel shelf end support. So it's never hard to find. And it's a decent size, ie 2kg. Not one of those coke bottle sized ones.
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
I know this is an old thread, but am resurrecting it to say that yesterday the same thing happened to my Td6: After a five mile gentle run I stopped but the left the engine running for five minutes or so, after which as I pulled away I became aware of smoke coming through the vents, and then realised that it was also emanating from under the front of the bonnet.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I have been doing some work on an 06 TD6 as it was immobilised and while running a snap on diagnostic we noticed a strong electrical burning smell and smoke poring out from behind the grill that I quickly sprayed with my garden hose pipe and disconnected the big plug at the top left of the rad. I removed the grille and tried reconnecting it without diagnostics plugged in and the same thing so left it disconnected.
For sure I need a new fan, and the options are:
This is the inside of the fan motor and its controller:
Nice pic, mine is staying disconnected, that would explain the smoke and smell then, i think they get water in to them being right at the front or do you think the insulation breaks down ? |
Despite the location of the fan I doubt that it's water ingress which caused the problem because the controller module is potted in a flexible silicon substance.
Certainly produce a lot of smoke when they go, not what i wanted to see when we are trying to start an immobilised vehicle.
