Home > Technical (L322) > Air Suspension Inactive
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
The air dryer is inside the air supply unit is it not, didn't think you could buy parts inside this unit? 2004 black Vogue TD6
Post #45571 11th Jan 2011 3:28pm
TugRR
Howdy again !
I was told the dryer is effectiveley a filter and as such should be a service item (but it isn't). Perhaps if it was there wouldn't be so many compressor problems ?, but I'm not suitably qualified to comment . . . . . Where do you go after one of these . . . ?
Post #45590 11th Jan 2011 7:12pm
V8 VOGUE
2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Mine came up with that fault to on the dash to,
In a panic took to local r,r guy about half a mile away
Now if what he says is true or not i will never know!!!
I have not used it for a whole week or more and its been minus temps at night!
He put it down to just that not enough charge in battery to power it up and as we were talking and car ticking over for about ten mins ...Out it went , all lights off no warning lights on dash etc Bow down
Took out yesterday and today for a bit of a run and its fine......I hope.
WHATS THINK ??????????
Post #47029 22nd Jan 2011 8:00pm
V8 VOGUE
Embarassed Thats a bit of a hijack sorry!!
Post #47030 22nd Jan 2011 8:01pm
bogie
it can be the battery ...you really need to get the fault codes read, cleared and see what occurs again
I had HDC inactive + air suspension inactive on/off for about a month, finally got it into a specialist and it turned out to be a wheel speed sensor - £20 part sorted it cheers
bogie
Post #47035 22nd Jan 2011 8:34pm
