![]() | Home > Technical (L322) > Aux Heater Question |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Same here regarding heater not listed on the computer, and I'm still baffled as to whether it has one or not? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
I enabled it on my td6 with a diag tool and it appeared in the menu.
Here we go....had to enable Aux Heat as well as Aux Cooling...
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
So I have read the post and it mentioned that you need to have a change over value fitted also.
All diesels had the heater as standard..... I assume you have a td6 as you have not filled in your car profile yet.
Yes I have the the TD6 model and it has aux vent displayed on the screen on the dash board. |
Mine was like that. It will only blow the air from outside in, to “vent” the hot air out in the summer so the car interior is no hotter than outside....or thereabouts.
Think this was the post I was looking for. Thought I’d posted more than the thread above....
