![]() | Home > Technical (L322) > Major battery drain |
| gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162
I saw this thread yesterday on the Disco forums, well worth adding a link in here in case any one else finds this thread searching for battery drain.
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
Great link. Just ordered a clamp meter. Oh boy! More tools I'll never really master. |
So if my door lock actuator is "broken" as iidtool says would this prevent the vehicle from going into sleep mode? |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Excellent news glad it is sorted |
| AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 81
Glad yours is sorted, my 2002 4.4 petrol saga might be continuing. Interior lights were flickering and fully charged battery wouldn’t attempt a start after three days sat on the car, EAS inactive etc. Alternator charging voltage typically 12.2 to 12.5v. Alternator tested and found intermittent, indy fitted exchange Bosch from Germany which has cured flickering and now charges at 14.5v. Also replaced Blowers resistor as a precaution. Car started fine this morning but this afternoon it only just cranked enough to start. Drove 10 miles to indy and got replacement battery at 4pm. Oddly the old battery was at 13.6v when taken off the car. Drove 25 miles home uneventfullya but noticed air suspension inactive message appeared as I turned the engine off. New battery at 12.6 v with engine off, will see what tomorrow brings.
I have just replaced the lead from the battery to the alternator and starter the lead was expensive at 120 odd quid as it comes remade with fixings etc - mine was done as preventative maintenance really after speaking to an indie who suggested it- my old p38 suffered from intermittent starting etc and it was corrosion internally in the leads from the starter to battery got round it by putting a second cable from the starter to battery - cost 6 quid
Good point. I had the indie check all main earth and positive connections, he repoted some corrosion so all were cleaned up. I haven’t checked the lug to cable connections yet though, retermination may be on the cards.
Sat in the locked car with interior alarm off. Car didn’t go the sleep and the sensor fan stayed running for over an hour. Curious thing, every minute there was a click behind the hvac panel and the fan stopped but immediately restarted. Also curious is that it was 5 seconds out of synch with the car clock over one hour so I presume it uses an independent timer.
Just to close my input on this one, before I got to do install the relay the rad blew so I had it recovered to my indie. Whilst it was there he called to say he’d found someone with one new sub-harness to do the official modification to the HVAC, last one on the shelf. Three days of testing later and it appears to have solved it 😀. Hope it stays that way! |
| All times are GMT |
