Home > Technical (L322) > Forward allert not avalible. Any thoughts
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all, I have had my 2010 vogue se for 18months now without the slightest fault, driving along today and forward allert not avalible cam up followed by all the other messages.
I pulled over, switched off and on again and all was fine for the rest of my 200mile trip.
Now when I start the ff it comes up with the message, then goes out after 2 seconds, when I check for faults in the info center there is no fault there. Any ideas ? Thanks Dave
Post #456086 4th Nov 2017 11:09am
dirt on the sensors maybe? ... - .- -.
Post #456087 4th Nov 2017 11:11am
Dogfishdave
I was thinking the same Stan, any idea where the sensor is ?
Thanks Dave
Post #456091 4th Nov 2017 11:27am
i knew you'd ask me that but i dont....some clever peeps will come along and tell us hopefully.. ... - .- -.
Post #456092 4th Nov 2017 11:41am
GraemeS
Australia
The radar unit is behind bumper, below the right headlight.
What were all the other messages?
Post #456093 4th Nov 2017 11:41am
^ told you so .. Thumbs Up ... - .- -.
Post #456095 4th Nov 2017 11:43am
GraemeS
Australia
I retro-fitted mine so should know!
Post #456097 4th Nov 2017 11:46am
Dogfishdave
GraemeS,
All the usual ones, hdc,abs ect but no restricted performance.
None of the other faults come up on starting just the forward allert not avalible.
Thanks Dave,
I will check the sensor and let you know
Post #456098 4th Nov 2017 11:46am
GraemeS
Australia
Forward alert not being enabled will be due to the ABS faults, not a fault with the radar unit.
You wont access the radar unit without removing the bumper.
Post #456101 4th Nov 2017 11:48am
Baltic Blue
I remember reading somewhere in the WM that the forward alert distance is adjustable, but can’t find it at the moment. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #456102 4th Nov 2017 11:49am
this might help Dave,
http://www.fullfatrr.com/forum/topic42067....ward+alert ... - .- -.
Post #456107 4th Nov 2017 11:52am
GraemeS
Australia
Forward alert distance (actually time interval) is adjusted by holding the ACC +/- buttons whilst ACC is not enabled, but nothing to do with not being available. However perhaps Forward Alert needs to be re-enabled via the instrument cluster option if the ABS fault turned off the option.
Post #456108 4th Nov 2017 11:54am
