![]() | Home > Technical (L322) > Struggling to start |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
can you fill in your car profile so we knew what you have... ... - .- -.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
sounds like glow plugs are goosed so not pre-heatin the derv up pal , id try new ones before doing anything else as you have to rule them out |
Stonie110 Member Since: 22 Jul 2017 Location: Huthwaite Posts: 5 ![]() ![]() |
Glow plugs have been tested and the glow plug relay has been tested |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Stonie110,
It is going in to garage next week for injector tests. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
If it's a TDV8, read on......
It’s the 3.0 td6 engine |
lesmcm Member Since: 12 Jul 2010 Location: Aberdeen Eastern Cape Posts: 30 ![]() ![]() ![]() |
Check the HP pump pressure relief valve on the back of the pump with a diagnostic tool the lp pump should read 3 bar the HP should be about 300 bar. |
It has been plugged in and both pumps are working fine |
