Home > Maintenance & Mods (L322) > Charging Battery via towing electrics?
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi everyone,
I’m looking for some advice / guidance. I do a very low mileage per year in my fatty,
mainly short journeys and want to keep the battery fully charged (new last year Yuasa 100 ah).
Plus, if we are to believe the met office predictions “a very cold winter is coming”. The old girl stands outside (too big to get in my garage) so will get very cold overnight.
I seem to remember reading somewhere that its possible to charge via the towing electrics?. As you will see from the attached pic below I have a Westphalia towing setup with 2 x 7 pin sockets.
Electrics is not my strong point so any guidance gratefully accepted.
Many Thanks
Peter
Post #456537 8th Nov 2017 3:20pm
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Just add a C-Tek Charger Thumbs Up
Post #456538 8th Nov 2017 3:39pm
Paul thornton
Wouldn't have thought you will be able to charge via the towing electrics as there will be a relay in there somewhere which will only latch whilst the engine is running.
Trickle charger would be your best bet with maybe a quick release connector to the battery.
I had a solar panel on my last car but it wasn't very effective if I'm honest.
Post #456544 8th Nov 2017 3:59pm
Baltic Blue
I regularly keep my battery topped up using a CTEK connected to one of the towing socket adapters I bought from the forum shop.
Brilliant bit of kit, so simple to connect .
I have the identical Westifilia towing setup.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #456545 8th Nov 2017 4:10pm
Strider
Well, Ive ordered the adapter from the forum shop and extension lead and CTEK MXS10 CHARGER.
Happy Days Thumbs Up
Thanks everyone Thumbs Up
Post #456569 8th Nov 2017 6:07pm
supershuttle
I used to do that all the time, used a ctek and the lead that is - never then failed to start even on the coldest of days.
I'm not sure there is a relay actually but there might be - anyway who cares it worked a treat. Thumbs Up Geoff
Post #456572 8th Nov 2017 6:25pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
dunno about any relay but I charge my Fattie up thru the tow socket with a Ctek and the forum lead
works a treat
Post #456575 8th Nov 2017 6:28pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
On the 12s socket (white one) pin 4 is permantley live and pin 3 is ground so you can charge using one of the adapters on the site shop using a ctek.
On a 13 pin socket pins 9 and 13 provide the same function
Post #456578 8th Nov 2017 7:05pm
Crispian22
Just ordered one of those adapters,looks a handy bit of kit!
I presume any smart charger will be ok to use?
Post #456582 8th Nov 2017 7:16pm
Jamiehol
Yes although the adapter comes with a ctek style connector. One of the nice things about the creek is the fact that when you turn the mains off but leave it connected to the car it remembers the charge setting which not all of the smart chargers do
Post #456586 8th Nov 2017 7:35pm
Crispian22
https://rover.ebay.com/rover/0/0/0?mpre=ht...1322969937
I've got one of the above,should be ok?
Post #456589 8th Nov 2017 8:34pm
Strider
UPDATE
Everything I ordered arrived over the weekend so today put the car on charge. I used the charger extension lead so was able to run it under the shut garage door with the charger on a block of wood iin the garage.
I turned off the car alarm while charging (was'nt sure if the current would trip it). Eventually fully charged light came on the unit Thumbs Up .
So anyone with the double towing electric sockets, this makes charging soo much easier, I highly recommend it Thumbs Up
Post #457133 13th Nov 2017 2:17pm
Crispian22
How long do these usually take for delivery?
Ordered on the 8th but no sign of it yet.
Post #457344 15th Nov 2017 10:17am
Strider
Hi Crispian22,
I guess I was just lucky, I did pm Martin Lewis and he did say that he has had a lot of orders (prob' weather related). It might be worthwhile sending a pm just to get an estimated delivery date. Mine took about 3 days to arrive
Good Luck
Post #457375 15th Nov 2017 2:44pm
Crispian22
Emailed them this morning and just had a reply saying it's been dispatched 1st class.
Hopefully here for weekend Thumbs Up
Post #457383 15th Nov 2017 3:16pm
