|  | Home > Technical (L322) > 2004 vogue heated front windscreen. Only half working... |
| Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481      | Not sure L322 specifically but I had this problem in my last x type.
|  8th Nov 2017 4:21pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135      | It might be something else, but might not.
|  8th Nov 2017 4:24pm |
| Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481      | After a quick look in the electrical library, maybe I was wrong.
|  8th Nov 2017 4:26pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874    | i'd go with Alistairs suggestion, check the 2 connections.. ... - .- -.
|  8th Nov 2017 4:46pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135      | Not sure on the L322, on the L405 - to remove the pillar, there's a screw behind the plastic airbag tab
|  8th Nov 2017 4:50pm |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545    | Cheers for your help guys. Think I need to pull the a pillar trims off and have a look.
|  8th Nov 2017 6:04pm |
| MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 621      | on mine passenger side about 10 lines work and drivers side about 3 or 4. Have deep chips in windscreen tho don't think that helps tho. Get less each year . | ||
|  8th Nov 2017 7:12pm |
| Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132      | Hmmmm, mines the same. Like a line straight down the middle, half clear and half frozen. Thought I needed a new screen.
|  9th Nov 2017 9:15am |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263      | If I remember correctly, if you pop out the Airbag plastic cover on the A pillar there is a single screw behind it then the cover comes off. | ||
|  9th Nov 2017 9:52am |
| Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132      | Thanks Paul, you're right.
|  9th Nov 2017 11:33am |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545    | You've inspired me to have a look at mine now!
|  9th Nov 2017 11:48am |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204      | if its the screen a ball hammer is good for a new screen replacement  | ||
|  9th Nov 2017 2:06pm |
| Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74      |
 It won't help with the heating, but might be worth saying that the first thing I did with my "new" FFRR was to use one of the windscreen chip repair kits on the deep chip with spider cracks starting to spread away from it. Called RainX and was on offer in ASDA at half price and cost about a fiver, if I remember right. It came with clear gunge. a plastic thing with 4 arms with suckers on the end and other bits. It worked brilliantly. No-one has been able to see where the repair is, the wiper wipe over it fine and the cracks have disappeared and stopped spreading. Old 110 2.3 Petrol ???? - ???? Old 110 200tdi ???? - 2004 1996 Discovery 300tdi 2004 - 2015 met fiery end being welded 2004 JEEP Grand Cherokee 2015 - 2017 2004 L322 Td6 2017 - | ||
|  9th Nov 2017 3:53pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
