![]() | Home > Maintenance & Mods (L322) > egr coolant hose leak |
andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104 ![]() ![]() ![]() |
Hi marks just done my o ring on the egr cooler and you have to remove the viscous fan and cowling then the front engine cover to get egr cooler |
Interestingly, a couple of months ago I replaced the egr cooler and the offending hose jubilee clip by simply removing the front top engine cover. It is a bit compact but it can be done without a lot of dismantling. I used a small ratchet and socket on the jubilee clip. |
marks Member Since: 07 Nov 2017 Location: leeds Posts: 4 ![]() ![]() ![]() |
ok thanks |
thanks will give it a go or two bottles of kseal !! |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
You can scrap the whole egr assy including the cooler by fitting an egr delete unit, blank for the exhaust manifold and 2x hose blank off's which I think are 15mm bore 2007 TDV8 VSE
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Do you need to have the ecu remapped if the egr is removed? |
On a TD6 no, just plug the vacuum hose. The best thing you will do for your car, the engine will love you for it 2007 TDV8 VSE
I could do with changing my thermostat so whilst in that area I may as well do the EGR delete as well I suppose. |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
Mine is gone I took it out at the beginning of the year
Are you running with no viscous fan as well?
Yes I took the fan off there are a few people on here that run without it seems fine |
Tempted to loose mine as well tbh. The noise it generates is horrendous.
its had the egr by pass and a re map it pulls like a train going to look at the bungs like you said thanks |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
@ Paul thorton
