![]() | Home > Technical (L322) > Heated steering wheel not working ? |
Yeah the red light will stay on until you switch it back off , maybe it's the element within the wheel that has given up the ghost ...... |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
ah well ..maybe an excuse for a new wheel then cheers
Better still a new FFRR |
LOL ...tempting it is...but my 2004 only has 50K miles on it ! ...its like new still
Surely you tested it when you bought the car? |
nope...never tested it ...didnt even know it was there until I read the manual !
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 ![]() ![]() ![]() |
now what you mean mine is coming up to 40k miles from new 04. |
there is a module under the airbag that controls the heating, i would be inclined to meter out the element to see if its faulty, V8 facelift Range Rover Autobiography 22" wheels.
cheers...Ive just got the workshop manual pdf and reading through it now too cheers
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
May be worth checking to see if the relay is "clicking" when you press the button. It is located on the back of the fuseboard in the glove box. When you press the button you should hear it click in.
ta - will give that a check tomorrow ...still havnt ordered a new wheel as I cant find anywhere with just a core in stock, I did find them for £130 ish, on exchange, but no stock
duka Member Since: 11 Jan 2011 Location: uk Posts: 147 ![]() ![]() |
sorry for bringing up an old thread, but my heated wheel doesn't work, the list doesn't come on at all. Looks like it's been a new wheel fitted (2006 model) recently, i've tried the fuse which is ok... any other ideas??
if a new wheel has been fitted, has it got the heated element and connected up?
sounds like I need to take the wheel off and check the connections or is there an easy way to remove a cowling or trim to check connections? |
