Home > Maintenance & Mods (L322) > One touch window closing
Webbie
I recently fitted a new battery to find I had lost one touch open and close on all windows. Fixed the one touch open by depressing and holding the button down. But I can’t seem to reset the one touch close. Any ideas?
Post #456890 11th Nov 2017 9:54am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Maybe wrong but , think you have to press and hold the button down and hold for approx 1 second when fully down and then the same again for fully up. That should reset the one touch window open/close function.
Post #456892 11th Nov 2017 10:01am
do the same, hold the switch up ... ... - .- -.
Post #456893 11th Nov 2017 10:01am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
This has worked for me.
Post #456901 11th Nov 2017 11:38am
Webbie
Pulling up the switch to reset has not worked. I had an Indy do the IID reset for the new battery install, could he have accidentally ticked a box to turn off the one touch window close?
Post #457069 12th Nov 2017 8:19pm
i wouldnt have thought so....so engine running and all doors closed and running the window down ,run window up and then pulling the window switch up for a while didnt work then. ... - .- -.
Post #457072 12th Nov 2017 8:31pm
supershuttle
Mine doesn't work on one window, rear offside, takes four button presses to open or close it. I've tried all the various fixes (like holding the button at the end of travel) but nothing seems to work. The Window doesn't seem to stick either but just keeps stopping at the same places every time. Geoff
Post #457074 12th Nov 2017 8:45pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
My front passenger window does the same bloody thing.
Would love to know how to fix it.
Going to try button holding tomorrow. Whether it works is another question entirely
Post #457101 12th Nov 2017 11:40pm
nino_nino
you may try putin something in thru the open window-like rolled up newspaper- so that window glass hits it going up and automatically retracts back down. it workt on my td5.
Post #457116 13th Nov 2017 10:56am
GAC23
Thank you ... will give that a go.
Post #457119 13th Nov 2017 11:02am
Webbie
I did exactly as above, but no success. All four windows have the same problem. All were okay before the new battery.
Post #457172 13th Nov 2017 8:54pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
I have just removed my battery as a reset. As soon as that happens the auto up/down feature stops working.
With the windows fully closed I start with the driver window, open all the way down to the physical stop, and then release the button completely.
Then once again hold the button down (all the way down) for a second or two.
During this period you will hear a soft dampened click sound from deep within your door, this is the window auto stop relay registering auto down.
Then wind your window up to the top, it will not go to the top automatically yet. Once it bumps at the top, ie fully closed, release the button completely, then again pull all the way up on the button for a second or two, you will hear the door click sound once again, its soft, but its there.
If it has not clicked, you are either releasing too quickly or only activating the window wind switch partially up or down in its full movement, remember the window switches have 2 detent positions per up or down stroke
Now you have auto up & down on the drivers window, repeat the exact same procedure for all the other windows, one at a time, from the drivers main window control panel, not the individual controls on each door, however each door will physically "click" as each door has its own window control module.
Good luck..
Post #457187 13th Nov 2017 10:29pm
supershuttle
Tried all the suggestions but still no joy, I guess it might have to be door card off and have a look Yawn Geoff
Post #457305 14th Nov 2017 8:30pm
Webbie
thank you marcochezzi, I will give your very comprensive instructions a try in the morning. It is different to how I did it previously, so hoping for success.
Post #457307 14th Nov 2017 8:51pm
Webbie
Unnecessary quote removed
marcochezzi, you are a genius. Your instructions worked perfectly, thank you.
Stan, could these possibly be Wikified.
Post #457401 15th Nov 2017 5:53pm
