![]() | Home > Maintenance & Mods (L322) > Red DPF Full Warning Again! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
i wasn't sure if it was seperatable Greg...
the WM says to cut and then re-clamp,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3870 ![]() ![]() ![]() |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
mine need the oil drain mod and the dpf then had a few issues, i had a hawkeye so could monitor it and see soot levels. the secondary problem i had was a leak between two of the sensors in the exhuast system that measure dpf soot levels. fixing the leak then meant the levels were recalculated (now with correct pressure readings) dpfs soot level went up and up but i just kept on longish drives over 55mph and its seemed to have coped so far (10k miles since) Cheers
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
I was reading this thread again.
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 358 ![]() ![]() ![]() |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
DPF is fine now, thank you. Whether the drain mod has helped - or not - I don't know. Just make sure to take car on a 40mph+ run every week and all's good. What do I put here then? |
