Home > Technical (L322) > Enabling TPMS using IID Tool
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Does anyone know, or could they have a look at their RR using the IID Tool, to see what the TPMS settings are so I can enable. Ive had a chat with Pat from GAP who gave me the settings from his 2010, but this hasnt enabled it. Any help much appreciated. Chris
Post #457134 13th Nov 2017 2:36pm
do you have the tpms valves fitted to your wheels Chris? ... - .- -.
Post #457135 13th Nov 2017 2:39pm
carpcat
I do Stan including the spare. I first tried a random setting in Tyre Pressure Monitoring 1 which then bought up the option on the dash settings for TPMS, but after driving it said TPMS was not available. Theres about 20-30 different options that I can choose, but dont know which one... Chris
Post #457136 13th Nov 2017 2:46pm
another question chris, were these the original wheels/tyres or something you bought after... ... - .- -.
Post #457137 13th Nov 2017 2:51pm
carpcat
Its a strange one Stan. Ive got the original spare but the 4 main tyres are from another RR. I dont know whether they were the same year. So yes this could be the issue, but if I knew the right settings I could know for sure. Chris
Post #457138 13th Nov 2017 2:56pm
i see what you mean about all the different iidtool settings re tpms ,
i would go for 'tire pressure monitoring 1' as 'undefined'
and 'tire pressure monitoring 2' as 'tpms fitted'
not sure re those settings but its an educated guess...
another possibility is that you dont have the sensors fitted ...you can check by having a look at the following,
Post #457139 13th Nov 2017 3:20pm
..........forgot to add,
if you go to this site ,the build sheet will tell you if you have tpms or not,
https://www.vindecoderz.com/ ... - .- -.
Post #457143 13th Nov 2017 4:30pm
You must be the first person to want to enable TPMS, most people find it very unreliable and produces false alerts. Got - 2017 SDV8 Autobiography in Loire Blue
Post #457153 13th Nov 2017 6:20pm
carpcat
Thanks Stan. Looked at my build on VIN site and it has TPMS installed. I have tried your settings suggestion and it at least now has the TPMS Warning light come up during ignition on the dash during the light check, so a good start! I guess I need to drive a bit for the system to register the valve sensors. Chris
Post #457195 13th Nov 2017 10:53pm
sounds like a plan Chris.. Thumbs Up ... - .- -.
Post #457197 13th Nov 2017 10:54pm
Blair
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I've been having issues with mine since fitting 2016 wheels and sensors. I believe they changed the sensors around 2014, and the new ones won't work properly with an older car.
In the end I just disabled it with IIDTool!
Post #457229 14th Nov 2017 10:22am
Simsy53
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Anybody no the settings in the ccf to reactivate tpms in a 2011.
Post #495388 12th Nov 2018 5:53pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Oddly I had been having issues with the original TPMS system on my 2007 RR, it operated occasionally but mostly it showed a TPMS system error, I changed all the sensors for new but it made little difference, just recently I fitted a set of take offs (2018 20”) from Dan, since then my TPMS system has been much more reliable......so not sure what’s going on here. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #495389 12th Nov 2018 6:04pm
