![]() | Home > Technical (L322) > Air suspension: Compressor exhaust valve removal |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
The air pipe fittings have a ring round them where the pipe enters the fitting this ring has to be pushed towards the fitting to enable the pipe to be pulled out in other words push the ring pull the pipe Porsche Cayenne
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Is it possible to post pics? As this is something I'd like to do.... |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
That's what she said... ![]() No seriously though, good info, thanks! ![]() |
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Guys,
Some of the filters screw out and others are a press fit. Best to use something like a pair of water pump pliers and hold firmly whilst turning it anti-clockwise |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
Im not sure which model you have but the 06MY WSM says to press in a retaining pin and pull of exhaust. I can be anymore specific I'm afraid as that's all it says.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 832 ![]() ![]() ![]() |
I think we're talking about the circled part in the picture:
From what I've been told some are threaded and some are a press fit.
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
It just unscrews modified part has a hole in the centre of the filter 2011 4.4tdv8 vogue black with black
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
my motor was in the garage today as it was saying suspension fault every time it went up or down
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
i would say your compressor is struggling, hence slow and overheating so yes new compressor time. 2004 black Vogue TD6 |
