Home > Technical (L322) > Timed Climate without FBH?
Blair
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Is it possible to enable and use TC without fitting the FBH? I only intend to use it for pre-ventillation.
I'm considering taking my fatty to the Caribbean, so never cold but always hot! One of my reservations about taking it is how slow to cool the aircon is from first start.
Mine is petrol, so no FBH as standard. I have IIDTool, so can theoretically enable it, but will it simply fault when it fails to detect the FBH?
Post #457499 16th Nov 2017 1:03pm
the timed climate is linked to the fbi so i would say no..
you can globally open the windows with the remote though... ... - .- -.
Post #457500 16th Nov 2017 1:05pm
Blair
Censored , I suspected as much!
Is it a massive job to retrofit (if I can find a petrol one)?
Does the TC turn on the full climate control system, or just switch on the fans?
I currently am having a slightly unstable train of thought involving a second battery, Timed Climate with remote, and an electric air con compressor from Nissan Leaf or similar in parallel with the standard crank driven pump...
Post #457502 16th Nov 2017 1:13pm
mjdronfield
Sure my 1988 735i had timed vent, and that had no FBH.....
Have you no option in the menus then? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #457542 16th Nov 2017 8:27pm
Blair
No options at present, but I can switch it on with IIDTool. Just wanted to ask the question before I try it.
Post #457550 16th Nov 2017 8:53pm
