![]() | Home > Maintenance & Mods (L322) > To flap or not to flap? |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Like this?
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670
Yes. But with a FFRR. What do I put here then? |
It will be pretty much the same as any other car, especially estates. The flatter the back the more turbulence is created with corresponding vortices which "curl" the air flow up the rear of the vehicle.
| brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275
No flap will help this time of year
Thanks for the explanation. And looking for a FF video. Still fascinates me how the dirt must get blown around. What do I put here then? |
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
I flapped and don't regret it.
You don’t need to drill the holes in the bodywork to fit the mud flaps! The idea of the drilled holes are to:- A, pull them tight into the bodywork (BUT, use a good quality double sided tape and that will do the same) B, rigidly fix them for off road use (BUT, if you don’t use/work it off road then they are an overkill IMHO) Oh and NO mine does NOT have them as i think they are ugly! Wifeys D4 does as they are smaller and more descreet |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Only have my 2011 a few weeks and it came without rear flaps but the amount of dirt on the rear quarters forced me to put on flaps. I orefer without but i dont notice they are there.now. 2015 4.4 AB
| finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120
An advantage of flaps is that they reduce spray, in the wet, at high speed and are therefore a road safety feature. For example if you take a look, HGVs are fitted with big flaps and also the inside lining of the flaps have a mesh or multi-spiked surface. This is to reduce spray and is very effective. |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389
Still undecided! Opinion seems to be 50/50!
| Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570
I took mine off whilst I replaced the side steps & although I initially liked the look without steps & flaps. I still prefered the look with them & side steps.
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
I have had 16 Range Rovers, some with and some without flaps.
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
I have flaps front and rear. They don't stop the back of the car getting dirty. As others have said that is just a product of the shape of the car, likewise one should avoid driving with the tailgate open and the windows closed as then exhaust fumes get sucked into the car. The flaps are good at reducing the amount of mud, stones etc thrown along the side of the car (front ones) and behind (rear) the latter being relevant also to convoy driving off road (risk of stones being thrown at following vehicle). With all terrain tyres more is thrown, and further, making the flaps more desirable.
| unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130
One thing no-one has mentioned. I found that rear flaps affect straight-line stability at - ehem - 'continental' cruising speeds. I removed the ones mine came with and the difference is really night and day. |
| All times are GMT |
