![]() | Home > Off Topic > Hardcore IT Question |
Our company has recently bought/merged with another company. The powers that be have decided they want a new (website & e-mail) domain encompassing both, and of course, immediately.
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 ![]() ![]() |
Dan,
More info me? ![]() |
Lookers Park Royal Member Since: 30 Apr 2008 Location: London Posts: 463 ![]() |
Microsoft Exchange?
We run Exchange 2003 in both locations, as well as seperate AD's in both locations with a trust between the two. Question - when exchange connects to an e-mail host server does it retreive ALL e-mails or just e-mails that belong to its known mailboxes? I appreciate that is a vague question ![]() D ![]() |
Dan, your exchange will be hosted on servers outside your building in a data centre (Not your servers)... you rent per user. You just configure outlook to connect via HTTP Job done, no hassle... A piece of Pi ss to configure... |
Hey, then you will be (sort of) "in the cloud"... |
MS Exchange can be configured to host multiple email domains on a single Org. It can also be configured to relay for specific domains.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3265 ![]() ![]() ![]() |
dan, have you tried switching it off and starting it up again? (I'll get my coat!! |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
We've done it using this method a couple of times Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it ![]() |
Thanks guys, ran out of time at work to finish this discussion. We have litterally been given a couple of days notice to implement this. It aint guna be pretty.
Hmmm, that's a recipe for a train wreck. If you want help with the planning shoot me a PM with some contact details. Seriously, if you've ever been in the middle of a MS Exchange collapse you'll know it's more painful than amputating your own genitals with a blunt instrument. Write out your plan, get someone to check it and then get a second review from another person. at the same time, write your backout plan and clearly identify the point of no return in the timeline. I assume you're going to do this over the weekend, yes? You need to think about MX records, DNS replication etc etc. Also think about where the mail is going to stack whilst you're offline. Again, do you have a perimeter mail hygiene device? Perhaps build a quick & dirty IIS box to collect the mail whilst MS Exch is offline. Essential pre-requisites would be: MX records. Add a second (Higher cost) pointing to the server which will be the main host for all 3 domains. Do it ASAP so the 13 root servers replicate it out. Don't forget the PTR record while you're at it. Add the C.com domain to the main server ASAP. Test it out thoroughly and use a recipient policy to add addresses to a few selected test users. Only once this is working properly should you then try to swing B.com over. I would go for the following weekend personally as it gives time for proper testing. At that point, migrate some test users from B.com to the new box and test that mail can be sent and received internally from A.com and C.com. Then test that B.com can send from the new box to something like hotmail. receive can't be tested until you drop the SMTP daemon on the original B.com box. Think about how you're going to move mailboxes over. Exmerge is a great tool but doesn't update the Outlook clients. The Move Mailbox tool is OK in smaller batches and does update the client. Unless these mail orgs are tiny (<100 mailboxes) you need to think about comms links and mailbox sizes when choosing your tool. Last, and most important, what is your DR plan? How recently was it tested? You might just need it. Dom. |
Very true indeed.... |
