![]() | Home > Technical (L322) > Testing speed sensors. |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Some youtubes links
| Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128
Thanks for the information Joe, i have watched several of those videos to make sure i was on the right track, i first tried to check the sensors through the main plug on the ABS ECU and then i tried each sensor to eliminate the possibility of a damaged or broken wire, so i will get a known good sensor and see what is what.cheers. |
Well i am back again |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349
Hi did you ever resolve the problem , you had measuring the resistances .
