Home > Technical (L322) > Advice on emergency jump point please
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
So we've booked a road trip to the Alps 6th January and I have one concern that the battery runs flat with the FF being parked in the cold for the majority of a week and we won't be able to get in with the dodgy driver's door lock.
At the moment there is a crappy bit of brown wire to the +ve that the FF can be jumped off of to open the door.
As a precaution I was thinking of running a 35mm battery lead from the +ve terminal to tucked somewhere under the front grill with an insulated cap over the end, then in an emergency locked-out situation someone can just hook jump leads on and we can get it
1 do I need one that big (35mm) to get some charge to open the door?
2 Is this a sensible/best option (I thought about an Anderson but then the average person with a set of jump leads won't have an Anderson connector)
3 Any other suggestions (obvious one replace the door lock! Whistle )
Post #458330 23rd Nov 2017 3:53pm
Do you have a tow bar and the two sockets?
Post #458338 23rd Nov 2017 5:02pm
ohuntsman
No I don't have a towbar, maybe in a year or tow
Post #458339 23rd Nov 2017 5:28pm
ohuntsman
two** Rolling with laughter
Post #458340 23rd Nov 2017 5:28pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Ditto: On mine ,"Pin 4" on the White (12S) towbar socket is permanently live.
Post #458341 23rd Nov 2017 5:33pm
ohuntsman
Sounds like we need to get a towbar!
Post #458343 23rd Nov 2017 5:52pm
Blair
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
An Andersen might be a good call, then make up an Andersen to jump lead setup to keep in the tool kit. That way you're not relying on someone else having jump leads.
Post #458349 23rd Nov 2017 6:21pm
Going back to your first post.
1 No you don’t need 35mm² cable, 4mm² would be more than adequate and robust enough not to get damaged.
You could connect a red cable to the +ve jump post and a black cable to the -ve jump post and run both cables to behind the front grille. I’d be inclined to terminate each cable in plastic cable connector to ensure nothing untoward happens. No doubt you can figure out how you intend to connect to the cables when needed.
To be absolutely sure about protection for the red cable I’d be inclined to install an in-line fuse holder in it near to the jump post with a 20A fuse in it.
2 The above is probably you best bet in the circumstances.
3 Without doubt I’d sort your door lock problem. Urgent imo.
As above get yourself a set of jump leads, just don’t leave them in the car. Wink
Just to clarify, my suggestion of using 4mm² cables is to allow you to connect a battery charger or to another car battery to allow you to open your drivers door not to start the engine. Once you get into the car you can open the bonnet and connect onto the jump posts directly with jump leads to start the engine.
Post #458351 23rd Nov 2017 6:57pm
ohuntsman
I actually fixed the key lock - took about two years + five minutes to do the job Rolling with laughter The column wasn't aligned with the locking mechanism Rolling Eyes
Thank you nicedayfor it will do that. I have some inline fuses too
Post #458367 23rd Nov 2017 9:01pm
