Home > In Car Electronics (L322) > Remote heating fob
OtleyDominic
Remote heating fob
Need a bit of guidance.. I press the button on the fob and it goes red, green then flashing green, but nothing happens in the car. Am I doing something wrong?
Post #457850 19th Nov 2017 5:15pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Flashing green should mean the FBH is running.
Why it isn't is another story entirely.
Someone with more technical knowledge than me will - I hope - be able to give you some clues to follow. What do I put here then?
Post #457944 20th Nov 2017 3:40pm
GAC23
Forgot to say ... have a look at the Wiki on this site.
There’s info on the FBH. What do I put here then?
Post #457984 20th Nov 2017 8:35pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Zeppfish sent me this recently....
https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf
answers a lot of questions....first red light usually means replace battery in fob...but if you set it up in the car i.e. via the menu that will probably not work either as mine does the same with the green flashing light...its going to the dealers so will let you know what the fault is.... I need more help than most...sorry !!
Post #457988 20th Nov 2017 9:11pm
bishbosh10
I'd change the battery first - a cheap and simple step that eliminates one unknown.
i did that after trying re-pairing and asking lots of questions on here and lo and behold! FBH works perfectly! Very Happy Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #458378 23rd Nov 2017 11:23pm
muppet
spookily the new battery arrived today and as the temperature was -3 I decided to give it a go....All green, starts flashing, blower comes on, noise under wheel....25 mins later opened the door to a lovely freezing car as the blower was still pouring out cold air...I give in..!! I need more help than most...sorry !!
Post #458432 24th Nov 2017 5:29pm
