![]() | Home > Technical (L322) > Heated windscreen - is it working? |
Lee Marsh Member Since: 21 Nov 2016 Location: Herts Posts: 44 ![]() ![]() ![]() |
Anyone know of a way to check if the heated (front) screen is working? Had my screen changed and not convinced the heated elements are working. I'm sure it cleared frost in a matter of seconds last winter
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
put cling film on the screen and try .... ... - .- -.
Thanks Stan, I'm not sure how that would work, but can plainly see it's only clearing from the blower at the bottom of screen while the rear screen clears quicker, without any added air.
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
Get up early, pretty sure most places are forecast a frost overnight, mine is lightly covered now.
Yh thanks mate, went out there few minutes ago, it's frozen but no lines vertical clearing as there are (horizontal) from rear screen.
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
OOOO had ours done Tuesday by Autoglass, guys seemed decent enough and Pilkington glass was fitted, and am about to start it up in the frost.... |
Rats! in the time it took to pour a coffee the sun beat me to it!! |
Whereabouts AJ are the electrics below the screen, and are they visible? Guessing the scuttle needs removing... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
You can feel the screen get warm with your hand.
Guys from National Windscreens had a look and suggested all connected up ok. Problem is, it still doesn’t heat up. Theyve said ‘it just takes a long time and doesn’t get very warm’. The connections are in the drivers front A post and is just regular type clips, no studs and bolts etc.
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 79 ![]() ![]() |
Apologies Lee, I missed your question. The P38 had a stud welded to the outside of the body on the centreline of the car, immediately below the windscreen. Remove the trim below the windscreen and it should be obvious. Two leads came off the windscreen and both bolted to the stud. After the stud was sheared off the earths were self tapped to the body which I wasn’t overly happy with as the screen pulls a reasoable current.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1477 ![]() ![]() |
That's rubbish, a genuine heated windscreen will start clearing the screen in a few seconds. I suspect they may have used a cheaper screen. Can you see the lines of the heating elements? 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Got them to change screen, as not heating up as previous (original) screen. Hasn't been cold enough yet to check if any better. Not going to hold my breath on it tho. They again used a NordGlass.
