Home > Technical (L322) > Electrical problem with 2011
funnyguy1
United States
Went to start my 2011 SC and red park light on right side of cluster blinking, green lo mountain light on left side, faults say no ABS, glove box won't open, disconnected battery and connected but nothing and it stuck in the garage in Park with no power. Don't know how they will get it out. Anyone had this. I hate electrical stuff!
Post #458627 26th Nov 2017 8:33pm
Paul thornton
Is the battery flat?
Post #458632 26th Nov 2017 9:31pm
funnyguy1
United States
Hi Paul,
I think thats exactly the problem! I jumped it with my wifes car and it started right up!! Had never seen so many
warning lights go on and thought for sure it was a module but its starting right up and tomorrow
I will replace the battery! Thanks again!!
Post #458650 27th Nov 2017 2:23am
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Could also be an alternator problem, if the battery was flat.
If you can measure the voltage across the battery with the engine running it should be approx. 14V.
Thumbs Up 2012 Westminster 4.4 TDV8
Post #458651 27th Nov 2017 6:53am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Should be approx 14.6
Post #458652 27th Nov 2017 7:05am
funnyguy1
United States
Boy! you guys are good!! Thanks! Will check voltage.
Post #458686 27th Nov 2017 4:35pm
nino_nino
I believe that the car has smart charging ecu. so depending on the need it will charge from 13.8 to 14.6 V it is fuel saving thing.
Post #458719 27th Nov 2017 8:39pm
Sandyt
Yep 13.7 to 14.6 give or take .1
Post #458736 27th Nov 2017 10:12pm
funnyguy1
United States
Just installed new battery! Everything back to normal!!
Post #458953 29th Nov 2017 9:50pm
Sandyt
Excellent news Thumbs Up Thumbs Up
Post #458957 29th Nov 2017 10:14pm
