![]() | Home > Technical (L322) > Key battery low and no start |
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 79 ![]() ![]() |
Re the above, I mean if the key fob battery has to be good for the car to start, the car battery is new as is the alternator. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1418 ![]() ![]() ![]() |
You don't say what car you have, but my experience is that a low key battery warning is given some time before the battery actually goes flat and post-warning there seems no change to the car starting.
It’s a 2002 L322. Could be the starter but I’m going to look at the leads first. Someone suggested internal lead corrosion, I had a similar problem on a P38 which had corrosion where the main lead copper under the lug had oxidised. I fixed that by twisting the lug off, cleaning it and filling the joint with solder. Worked fine. I later had a similar problem with the solenoid cable spade connector, a new lug soldered on fixed that too. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
I had the corrosion easy fix is to buy another lead from auto factors for about a tenner and just wire it in in parallel and see if it solves the problem if so just replace the faulty one - on my p38 I just left it connected but the fatty has the disconnect charge fitted |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Change key fob battery |
