![]() | Home > Wheels & Tyres > Snow chains will they fit?? |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I have 255/55-19 and have seen these advertised:-
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
Snow chains in Surrey ...Ya
Thank you Alistair - it is the only 19 inch size listed so the numbers def won't stack on the others...
Leatherhead ?? |
Leatherhead? Am I missing something? |
Only pulling your leg
Which I don't mind - I just don't get it! |
a bit more expensive than your link but these specify your size tyre,
Good spot Stan and a good price still |
i did just that |
I am such a Leatherhead (still don't know what it means) |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Overall size is the same - smaller wheel but taller tyre - so you need the same size chains ![]() The sizing isnโt that precise, you basically tighten them onto the tyre - so a given set of chains works across a variety of different tyre sizes. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
they are the same type as mine iirc, but I have set 450 I think which fit the 255/55 19โ and 255/50 20โ. I will have a look.
Thank you pal - I didn't go for them in the end, I wanted to go for Stan's find but didn't order then it started snowing and they doubled in price - so went for these instead
