Home > Technical (L322) > Weird brake locking = akin to traction control kicking in
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
L322 TD6. We have had very heavy rain here, and yesterday whilst reversing out of my drive way I heard a loud thud noise like I had run over something, The air suspension and HDC fault warnings popped up on dash as well as 3 warning lights. IIDtool BT showed left wheel sensor signal implausible. I cleared the faults, drove ok. then again it happend it seems the wheels locked up. Cleared and drove home. This morning went to move her out of the drive way and it seems like the traction control kicked in and locked a front wheel or something .
It's Too wet outside to pull the wheel off and check anything at present due to heavy rain fall.
Post #459400 3rd Dec 2017 4:50am
nino_nino
lov, drum brakes -( EPB on RR), can swell with moisture and lock the wheels . if it continues to happen, release the EPB a notch with adjustment wheel.
Post #459402 3rd Dec 2017 7:16am
lounge_on_wheels
nino nino, it feels like the front is locking, but will check the rear drums. I did have rear drums lock on me once before as the shoes were U/S. I replaced the shoes and all was ok after that. Seems a stupid idea if you go through water and the hand brake shoes swell Evil or Very Mad
Post #459404 3rd Dec 2017 8:39am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hiya,
Similar thing just happened to mine - abs sensor down and the hill decent kicks in over 3 mph - Booked in with the indi at the moment , however at his advice pulled the abs fuse and it's now doesn't kick in.
Hope that helps
Simon
Post #459416 3rd Dec 2017 10:13am
mjdronfield
Does the speedo work?
On my TD6, the reluctor ring that the speed sensor reads from rusted through on the rear left side. That feeds the speedo. As it doesn’t get a signal it thinks the car is stationary, so when it gets a speed reading from the other 3 when you are going down the road, it assumes they are spinning, so activates traction control and reduces engine power......
If it is that..... worth a look...
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #459435 3rd Dec 2017 2:32pm
lounge_on_wheels
Speedo works, I think my hand brake shoe is sticking on and since the rear wheel wont rotate it must send a signal to the ABS to lock the other wheels also. I won't know until I pull the wheel off and check the rear brakes.
Post #459515 4th Dec 2017 1:39am
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
It's a abs sensor front faulty scared living daylight out of me always in wet.
Post #459532 4th Dec 2017 10:53am
holidaychicken
I had the same thing after heavy rain and also car had been for it’s MOT so may have got upset with the wheels dangling down.
I went through a big puddle and EAS inactive came up and then next day HDC kicked in putting the brakes on as I reversed off the drive then HDC, ABS, EAS inactive then would drive fine. The ABS sensors were new but britpart so I took them out and gave them a clean and had to clear the fault a couple of times but have been fine now for a year .
Post #459587 4th Dec 2017 8:11pm
lounge_on_wheels
Holiday Chicken, may be dilectric grease is needed on these sensors to repel water?
Post #459634 5th Dec 2017 12:49am
holidaychicken
That could well be the answer or something along those lines
I have britpart sensors and aftermarket outer cv joints and i figured it was water getting between the cv joint ring and the sensor although looking back over the old photos the old sensor was corroded in place and i cleaned up the bore where the sensor goes and if i know me i probably put some copper slip in the bore to stop it corroding again which may have upset it.
i cleaned up the sensor and put it back and it has been fine although i have not hit any big puddles since as far as i can remember.
Post #459635 5th Dec 2017 1:25am
lounge_on_wheels
I removed the rear wheels today and checked the brake shoes for binding, even removed the disc to check the condition of the shoes. All was ok. I then unplugged the front sensors at the connections and all was dry, I gave them a spray of electrical contact cleaner just for good measure. I disconnected the ABS ECU plug and gave that a spray with electrical contact cleaner also.
I went to take it for a test drive and immediately I had the brakes grab what appeared to be in the front. I ran out of time to do any more work on it so left it parked.
A few hours later I had my wife come out, I wanted to have her walk along side of the Range Rover and tell me which wheel was the likely cause of the noise of grabbing. but it didn't do anything abnormal. So next I took the Range Rover for a long drive and it performed as it should, no problems came up. So it's a mystery. Question
We don't have the extreme corrosion problems that you chaps in the UK have as we do not use salt on our roads
Post #459676 5th Dec 2017 2:45pm
holidaychicken
Have a search about regarding the ABS module as they can fail and give some strange problems
Post #459729 5th Dec 2017 9:00pm
bleeperman
Until you have substituted both left and right abs sensor and checked wiring you are looking too deep. I would also check you have not pushed too much copper grease down the hole it will attenuate a very small timing signal if not careful.
Post #460503 12th Dec 2017 11:36am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
http://www.fullfatrr.com/forum/topic40836.html
I had similar issue see post above 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #461887 23rd Dec 2017 12:15am
