Home > Technical (L322) > Rear subframe bushes - are they the same as the BMW X5
fisha
As it says, the rear bushes that join the subframe to the body of the car need done.
I've looked at the various posts on how to do it, which is fine enough, however there is a poly bush set for the x5 ...
I'm just wondering whether the x5 shares the same rear bushes as the rr ... They look very very similar. V8 or else ...
Post #111097 5th Mar 2012 10:41pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
This post is a bit old but I could do with the same question being answered please ! 2009 - L322 5.0 S/C Autobiography
Post #459302 2nd Dec 2017 1:43pm
Sandyt
As to your question I don't know but as a word of warning I put poly bushes on my p38 two different sets and ended up replacing with oem it does change the ride and handling - in my case it was too harsh - probably great for offload -sure someone will disagree Very Happy
Post #459411 3rd Dec 2017 9:51am
RS2000CUSTOM
Yep I understand regarding poly-bushes
The BMW X5 E53 tool is listed on Ebay £60 yet no mention of it suiting an L322
I need to replace my subframe bushes and anything to make it an easier process is appreciated - lol 2009 - L322 5.0 S/C Autobiography
Post #459419 3rd Dec 2017 10:42am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
The Sealey tool for doing X5 bushes fits the L322 perfectly as do X5 bushes (although there are some very slight differences in the Meyle HD ones that mean the lower washer simply has to be manually centred, rather than there being a moulding on the bush - doesn't seem to make any difference). I did mine earlier this year. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #459421 3rd Dec 2017 11:08am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
The rear subframe rear bushes on our late 2006 l322 are also kna»» **ered.
Which age range of X5 use compatible bushes?
It's a job I'll need to do sometime early next year. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #459499 3rd Dec 2017 10:24pm
RS2000CUSTOM
Now that is an answer I wanted to hear - many thanks sir ! 2009 - L322 5.0 S/C Autobiography
Post #459508 4th Dec 2017 12:05am
fisha
+1 ... I wish I had known that years ago. I essentially sold my old RR cause of the job of doing the rear subframe bushes ( it was 1 job too many, too big ) as I didn't have the right tools.
I'll know this time round ! V8 or else ...
Post #459592 4th Dec 2017 8:41pm
I thought you made a tool to do this fisha ? .
Post #459615 4th Dec 2017 10:41pm
rvbush
You're very welcome. I did mine in much the same way as described in the Wiki. It's time consuming and pretty hard work if doing it on axle stands, but it can be done. I did the upper and lower hub carrier bushes at the same time.
On the M62 V8 you need to lower the exhaust (doesn't have to be removed) by undoing all of the rear silencer mounts and gently lowering it on a jack and then supporting it. Those mounting bolts need very careful handling if rounding them off is to be avoided. I soaked them in WD40 for a few days (giving them a dose twice daily) and then got some heat into them from a gas blowlamp. Drives:
Post #459643 5th Dec 2017 9:08am
fisha
I kinda did ... but never fully finished it. It was all just one job too many at the time. It didn't help our son had just arrived, and strangely, the wife thought that I ought to spend my time fixing nappies than the car ... Question Question Question Rolling Eyes . Laughing Laughing V8 or else ...
Post #459645 5th Dec 2017 9:18am
