![]() | Home > Maintenance & Mods (L322) > Range Rover Misfiring and stalls at idle |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 809 ![]() ![]() ![]() |
well it reads like you sucked water up into the engine but that seems very unlikely , is ther any smoke from the exhaust ? |
milleR Member Since: 05 Dec 2017 Location: North carolina Posts: 4 ![]() ![]() ![]() |
None. I ended up starting it a day later and it works now. My belief is the cam shaft position sensor went array and it just re-adjusted itself afterwards. It runs no codes (so far). Everything is smooth and fine |
ghost in the machine perhaps ? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Could be the fuel pump is on the way out. They tend to be ok one minute and faulty the next only to be ok for a while again.. ______________________________
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Could be something simple, crank sensor, cam, sensor etc.
Sorry Gents for not responding in a while. Just wanted to say she’s still going. I asked over at RangeRover.net and RRtoadhall seems to believe it was the crankshaft position sensor that got wet and then dried off and it started back up. The mechanic who looked at my car thought the same thing (I did not tell him the theory). Well, with that said I think the same. Rangie has been working for 1,000 miles so far and kicking it. I replaced the fuel filter a year ago or so solely out of maintenance so I don’t think it was a problem. When the incident happened, the car drove a little bit and just outright acted.. weird for 5 seconds and then the engine just stuggled to rev normally. After 10 seconds of struggle it died. Repeat. Now it’s fine though after it took a day to dry off though.. Hope this answers all for now and in the future! |
