![]() | Home > Maintenance & Mods (L322) > Refurb G/Box supplier? |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I just had mine done at A1 Premier in St Neots. Might be a bit of a way but the price was OK, and it drives beautifully now. Just over £2K with the converter. They flow test the oil cooler too and replace if needed. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Ah ok. Could be an option. Thanks!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8022 ![]() ![]() ![]() |
Not super convenient, but if you want it doing properly, then RRPhil is your man |
bertie1 Member Since: 30 Sep 2017 Location: kent Posts: 100 ![]() ![]() ![]() |
im sure range rover phil only does the v8 range rover gearboxs not the gm boxes on td6 engines |
iv heard good reports of Suffolk transmissions google them |
Im pretty sure its only the boxes with the bmw m62 engine ie v8 not td6 |
Cheers so much guys. Distance isn’t a major issue as it still drives in sport mode.
i do know that when I took my friends fatty with him to Suffolk transmission the guys where great tested everything etc the only thing is its a bit far out but il go there when I get problems forsure good luck hope all gets sorted and doesn't clear out the wallet before Christmas |
Thanks so much.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
It's the other side of the M25 from you, but STA in Aylesbury (https://www.staautogearbox.co.uk/) have been used by a few people on here including me and have a very good reputation. If I had another full fat, then I would use them or RRPhil. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^^ I second that... And a little secret... if you ask nicely they will fit a brand new torque converter (as opposed to rec) for about £100 more! Well worth doing |
Oh awesome! Thanks for the info.
Druboo Member Since: 04 Jun 2017 Location: Wiltshire Posts: 12 ![]() ![]() ![]() |
I'll third it Very impressed with STA and new converter fitted. Also modify the control block with upgraded control valves and you get a warranty for your hard earned. ![]() |
