Home > Maintenance & Mods (L322) > Adaptive dynamics fault
Page 2 of 3 <123>
GGDR
Well done Thumbs Up Thumbs Up
If you're going to replace the loom section, please do share pics, links, prices etc.
In terms of your grommet you might get a year or two out or it so up to you - as you've seen those res are brittle so could go in another place which supports your logic of replacing the loom.
Happy to help, all the info was here if you dig a bit - but it's also always a boost when you're tackling something new as I have done myself and had others chime in to help.
Some think the ride is choppy while the fault was active.
Anyway, enjoy your successful fix mate! If only all RR fixes were that easy huh?
Greg. Cheers, Greg
Post #459317 2nd Dec 2017 3:38pm
Deegs64
United Kingdom 2011 Range Rover SE 4.4 V8 Barolo Black
Easy Greg.....felt like the fecking krypton factor 😂😂 only joking mate,was indeed simple and once again thanks. If I send for the looms then I certainly will have a go at picturing and posting mate. Wld u believe it, my nsf window stopped working this morning and I’ve fixed that too 👍🏻 Found a little reset procedure online that worked too. Happy days. Thank you to everyone who posts help on these forums.
Post #459320 2nd Dec 2017 3:50pm
SinbadRose
Evil or Very Mad
Mine has come up today, so looks like a job for the weekend if the weather stays calm Rolling with laughter like that will happen.
Post #459785 6th Dec 2017 1:31am
Deegs64
Mate mine drove me mad but the guys in here was marvellous. It’s easy job and that’s from someone who hasn’t a clue 😂 just shout if U need any guidance
Post #459833 6th Dec 2017 6:00pm
SinbadRose
Well decided as the snow/rain/wind is coming in, decided to do it tonight. Took a whole 10 mins and that included finding my bits to get the top off Smile
Yet again the forum has saved me from the wife having a moan about my choice of car Smile
Post #460067 8th Dec 2017 6:56pm
Deegs64
Well done mate. 👍🏻
Post #460083 8th Dec 2017 11:57pm
Baltic Blue
Don’t let anyone tell you that FF’s aren’t vindictive!!!
B.B. is always garaged overnight, except the last couple of nights whilst we have been away and it has been parked outside on the Hotel carpark in temperatures well below freezing and snow showers.
Set off home this morning and within 100 yards, “ Adaptive suspension alarm “.
At least it started OK and I used the defrost button to clear all the windows, but I guess I will be out with the soldering iron as soon as it stops snowing. 😂😂 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #460124 9th Dec 2017 4:28pm
Baltic Blue
Not the warmest of days😁
But all sorted in 15 mins. (Screws are TX 30 )
Post #460527 12th Dec 2017 1:10pm
Baltic Blue
Typical, the postman has just delivered a pack of shrinkdown sleeves now I have finished the repair by taping it up, but I will be making a couple of short replacement harnesses when the weather improves.
If anyone wants one once I have posted the finished picture, I will be happy to stick them a couple in the post.
I have got enough shrinkdowns to make them for anyone 👍👍
Cheers
Post #460557 12th Dec 2017 3:46pm
nino_nino
It is Epidemic.
and as you said BB forum is golden, i would have panic if i did not know how easy it is to fix 10min tops.
btw BB put this on my list of faults. Very Happy
Post #460571 12th Dec 2017 4:44pm
Baltic Blue
Nino,
I am blaming the very cold weather for the sudden outbreak of “Adaptive Dynamic “ faults.
It has shot to the top of my list🤔🤔.
Happy Christmas
Cheers
Post #460573 12th Dec 2017 4:49pm
so is it correct that new looms were fitted around 2012 and if so how do you know.. ... - .- -.
Post #460575 12th Dec 2017 4:50pm
Baltic Blue
Mine is definitely old. (2011) Both sides have been repaired at least once before I bought it.
I have just done 2nd repair on LH side.
Nino’s is a 2012 ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #460578 12th Dec 2017 4:58pm
nino's 2012 made me wonder if mine is about to go Mike hence the 'new loom' question... ... - .- -.
Post #460581 12th Dec 2017 5:03pm
Baltic Blue
The answer is probably in LTB00416v3.
At least it’s easy to fix.
I am going to make myself 2 new looms when it warms up a bit.
Post #460587 12th Dec 2017 5:18pm
Page 2 of 3 <123>
