![]() | Home > Technical (L322) > Is this ticking noise normal? |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Non of those symptoms are very good or cheap to repair.
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 ![]() ![]() |
Millennium range rover specialists Surrey last serviced it and look to be the ones who put the oil in and overfilled it, assuming no one touched it since, of which I can not see they have from my records.
jeff88 Member Since: 03 Dec 2016 Location: hadigny, vosges Posts: 4 ![]() ![]() ![]() |
hello,
Thank you, I will bear that in mind and see how the garage replies |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8763 ![]() ![]() ![]() |
Nope not right, doesn’t sound pulley or belt related to me.
The cause of the issue is still unknown and the garage have taken the car back and agreed a replacement. They have since swapped the fuel pump and it made no difference. |
Well there's a strong argument for buying from a reputable dealer.
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
That's not a ticking noise, THIS is a ticking noise
That's not ticking, that is proper knocking |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Noise stays without belt? Was engine running without belt with the same noise? Best rgs L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
I have a replacement car from the garage. They tried the fuel pump, tensioners and oil change but noise still there apparently. LR believe it is warn tappets, but who knows! |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
I appreciate this is a very old thread, however does anyone know whether the original videos are still accessible somehow? I'm really keen to see whether this noise is the same as what I have. Thanks |
If you message me, I will try and dig it out |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 432 ![]() ![]() ![]() |
Was the cause ever determined?
