Home > Maintenance & Mods (L322) > Rocker cover gaskets...
Danwilderspin
Planning on following the diy on doing these but I may need to remove the rocker covers again in future if I ever need to do the guides and or tappets...
So I wondered once I have changed the gaskets can I remove the cover and refit again without changing the gasket set again?
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #459015 30th Nov 2017 11:04am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Your not really meant to reuse gaskets and for the sake of the cost for two new ones if it was me i would just replace them again.
Also if you use the dab of silicone in the spots your meant too when replacing to stop any leaks your old gaskets will have some silicone on them and would be hard to clear off without damaging the old gaskets. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #459038 30th Nov 2017 3:21pm
Danwilderspin
I think I will get shot down here but bimmerforums claim the cheapest and ieasiest fix is to replace the washers on the bolts with slightly thicker steel washers to make the gasket compress more.... thoughts? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #459865 6th Dec 2017 8:52pm
b348xyx
Up to you what you do, be careful not to snap the bolts if they get overtightened just make sure use torque wrench.
But personally just replace the gaskets it’s not a big job, little bit rtv gasket sealer on certain points when putting new on and should have no leaks for many years if all done correctly. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #459869 6th Dec 2017 8:57pm
Danwilderspin
Any ideas how many nm to tighten to? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #459875 6th Dec 2017 9:11pm
holidaychicken
Download RAVE as the torque setting is in there but it’s not that high. There are metal inserts that are fitted in the cover bolt seals to stop over tightening the covers.
The original seals turn to hard brittle plastic and mine all snapped up when I changed them. The important part is the correct loctite sealant either side of the half moon cut outs and also where the upper timing covers joints are.
If the seals have already been replaced before you could potentially reuse them but as already pointed out I would just replace them anyway, I used Febi ones last time
Post #460086 9th Dec 2017 2:19am
p38arover
Australia
I assume you mean Newton metres, not nanometres? Whistle
From RAVE: Left hand/Right hand camshaft covers nuts/bolts * 10 Nm 7 lbf.ft
* Correct tightening sequence must be followed Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #460087 9th Dec 2017 3:14am
