Home > Maintenance & Mods (L322) > Lights either side of thumbwheel - interior side vents?
Should the open /closed blobs (green and white) on either side of the thumbwheel on the interior side vents light up, like the ones on the centre vents. Neither of mine do, and never have.
If there are supposed to, is this an easy repair (assuming its a bulb replacement job!)
02 TD6 .
Post #45842 13th Jan 2011 1:09am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Re: Lights either side of thumbwheel - interior side vents?
dont think mine do 2004 black Vogue TD6
Post #45846 13th Jan 2011 1:30am
bogie
mine dont either, I dont think they are meant to cheers
bogie
Post #45850 13th Jan 2011 8:36am
dan_uk_1984
Although they are not meant to - they have the bulb holder in place to enable them to be lit, along with the plastic lights guide to allow you to use one bulb for two things.
Land Rover obviously wanted them lit but forgot, or thought it a waste of money.
Fitting lights wouldn't be hard, its on my list to do, just some way down the list!
More irritating is the non-illuminated stupid thumb-wheel.
Post #45854 13th Jan 2011 9:27am
letsavit2
land rover left them out as they was shining onto the side mirrors.
did i just make that up... Question Laughing 2004 black Vogue TD6
Post #46012 13th Jan 2011 11:48pm
Thanks Dan .
Post #46014 14th Jan 2011 12:53am
dan_uk_1984
I think you may have done! They don't need to be as bright as the sun, but some illumination would be nice.
Post #46015 14th Jan 2011 12:54am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I thought the same when I got my car, found it strange that they didn't light, a bit like the thumbwheel in the centre to adjust the hot/cold flow (i.e. 1-3 blue dots , 1-3 red dots). This does annoy me as I like a mildly warm temp in the car but sometimes want to warm it up quicker for other occupants , but at night, I can't see the markings on the wheel to put it back to 1 blue dot so end up putting the interior light on to see it. If someone now tells me this wheel has a bulb in it and mine has failed I won't be happy!! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #46151 15th Jan 2011 12:57pm
dan_uk_1984
No bulb in there Thumbs Up
The frustrating thing about the thumb wheel is the temperature there confuses the Climate Control - If you've set the interior temperature to 21C the car will maintain that, if the thumbwheel is set to hot or cold though the CC will constantly be fighting the air coming out of there.
Post #46152 15th Jan 2011 1:07pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
What is the purpose of this thumbwheel anyway, as only some german car makers fit it, the rest of the world does OK without it?
Post #46161 15th Jan 2011 2:38pm
Steve R
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
Not far from the truth - I believe they were switched off (before going into production I think) because their reflection in the side door glass at night was considered too distracting.
Steve. 2013 Range Rover Evoque Coupe
2013 Defender 110 XS Utility Wagon
1975 3.9V8 Lightweight
Post #48824 4th Feb 2011 6:53pm
dan_uk_1984
Steve.
Odd, every other car manufacturer manages it, and there are LED's all over the rest of the car. If you sit in the drivers seat they are not in your vision, nor would the reflection be...
I think it was more just a cost cutting exercise from BMW... Like the scissor jack for a 2 tonne car.
Post #48846 4th Feb 2011 8:11pm
letsavit2
Steve.
i have to say i disagree Dan;
as this might be the first time i knew something about the range rover that you didnt.... Laughing 2004 black Vogue TD6
Post #48866 4th Feb 2011 10:35pm
dan_uk_1984
You cant see the vents in the side mirrors though? So there certainly wouldnt be a reflection there at night... Take a look next time you're sat in your car.
Post #48896 5th Feb 2011 12:23am
letsavit2
right i just went out and set up a dummy bulb via a 9 volt battery, wow the reflection nearly burnt my headrest, go try it.
not to cause embarrassment you can pm me to say im the master ...... Rolling with laughter 2004 black Vogue TD6
Post #48899 5th Feb 2011 12:39am
