Home > Technical (L322) > TD6 Intermittent judder / injector fault
Page 1 of 5 12345>
Paul thornton
Morning all,
I get an intermittent judder which you can here whilst slowly reving the engine and occasionally can be felt whilst crawling.
Ive plugged the IID tool in and it's basically showing that injector number 1 is overfueling.
I'm thinking ive either got an injector or wiring loom fault.
Could a wiring loom fault cause it to overfuel though? I was thinking not as if it was a wiring fault surely the injector would do nothing rather than overfuel?
I know the answer would be to swap 2 injectors round and see if the fault moves but I don't want to do that for 2 reasons... 1/ I can get to injector number 1 without removing the inlet manifold, 2/ I'm led to believe the injectors are a pain to get out.
Any advise would be appreciated.
Many thanks.
Post #460189 10th Dec 2017 11:53am
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
If you don't want to fiddle with swapping stuff around, just throw a new injector in and see if it cures it. They're about £60 for a Recon one, so not the worst thing if your RR ends up with a new injector it didn't really need.
Post #460194 10th Dec 2017 12:41pm
miggit
^ I would say that your price is a bit light... by £100 ish, I paid £135 per injector for refurb by a Bosch Agent with warranty.... £60 is more like the second hand pot luck price!
And it does sound like the injector is in need of looking at, the fact that it's showing up on the IID tool would rule out a loom fault! Yesterday I couldn't spell Engineer... Today I are one!
Post #460229 10th Dec 2017 4:38pm
Paul thornton
Thanks guys,
Tbh, I'm not sure how the injection system works 100%
Is it just a positive and negative which comes out of the fuel injection ecu to each injector that open closes the solenoid or does it work off a resistance??
There a diesel specialist not far from me so I may ask them to test and if necessary rebuild the injector at least that way I'd know if it's actually faulty.
Post #460243 10th Dec 2017 6:05pm
miggit
The injector is just a coil.. bit like a relay for liquid! But the spray nozzle can get blocked.. the electrical side works fine but nothing gets to the engine...
If your engine is 80K + then getting the injectors cleaned and tested is well worth it... I had what I thought was 1 injector fail, but it turned out to be 2... ran like a sick pig on anything other that flat out, then it was a little sluggish but a lot happier! Yesterday I couldn't spell Engineer... Today I are one!
Post #460282 10th Dec 2017 11:48pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I got one of mine exchanged for a recon one whilst over in the UK, 80pounds courier drops off the new and takes yours, all included. Note these have NEW nozzles so it's an unbeatable price via ebay. https://www.ebay.co.uk/itm/BMW-330d-530d-7...Swr~dZjc~9 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #460312 11th Dec 2017 11:28am
Paul thornton
Spoke to the diesel specialist, quite a helpful chap tbh, he said the injectors wear out internally which causes them to overfuel and as mines reading +6 it's well goosed.
He advised service exchange would be my best bet and quoted me £125.00.
I'll have a look at the link above first though as that sounds like a good deal.
Post #460328 11th Dec 2017 12:19pm
miggit
It looks like an exceptionally good deal! Plus they supply a new washer!
Easy to fit if you are fairly good with a spanner... nothing too rocket scientist about the job... there are a couple of tricks that can help, if you're interested! Yesterday I couldn't spell Engineer... Today I are one!
Post #460333 11th Dec 2017 12:26pm
wayneg
What I did was pick up the cheapest used one I could find, make an offer on ebay, I found one for 20 pounds then did the swap with that. Still only 100 and you have still got the old one if you need a swap in the future. Takes any pressure off doing the swap. I was very impressed with the recon unit, New nozzle, pin and washer plus had plastic protectors on the inlet and nozzle, it would almost pass as new. Highly recommended. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #460341 11th Dec 2017 12:48pm
Paul thornton
Yep, think I'm going to go with the offer above as there's no surcharge doing it that way.
Just need to make sure I can get the faulty one out first as there's no cheap 2nd hand one's for sale, I did think of that.
Any tips for getting it out then? It's number 1 so at least I don't need to take the inlet manifold off!
Post #460344 11th Dec 2017 12:59pm
miggit
Step 1 car in low mode!!
Step 2 bonnet in service position (90 degrees)
Step 3 remove fresh air box.. undo the 2 13mm/M8 nuts and lift the box up and forward!
Remove engine cover and you're into the top of the engine!
One last thought it is probably better to do it on a hot engine.. as hot as you can get it, as the injector seals have a habbit of leaking and welding the injector in to the head... on my Mercedes it's a very common fault, and I have found that the black coal like substance is soft and sticky when hot!. Another trick is to loosen off the injector bolt a turn or two with the engine running, hopefully it will give the injector a little shove and aid removal... obviously don't undo the nuts a long way as it could result in bent injector pipes and a UFO Shocked
Once the injector is leaking, turn off and remove, if it puts up a fight WD it and wriggle it as you lift! Don't get the crow bar out as the top of the engine is plastic and could result in Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #460359 11th Dec 2017 1:30pm
wayneg
As above but I would use Plusgas not WD40. http://www.ebay.co.uk/itm/PLUS-GAS-Releasi...0704.m4779 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #460360 11th Dec 2017 1:41pm
Paul thornton
Thanks for your help guys, never thought of loosening the injector bolt and letting it pressurise itself out but that sounds like a good trick!
Post #460372 11th Dec 2017 2:24pm
miggit
As I said do it on a hot engine and only a couple of turns on the nuts.... I can't remember if you can get to the injector with it all connected, you might have to loosen off and then crank the engine... DON'T disconnect the fuel pipe as it will flood the place Shocked with the engine on!
To be honest it's been a couple of years since I've been in the top of a ffrr engine, I have gained more recent experience with the Merc, which is a bloody stupid one bolt design and fails on a regular basis, so regularly it is know as 'The Black Death' Shocked
But like the BMW engine the injectors can weld themselves in, and the hot engine and loosen the bolt with it running are tricks that I've picked up for the Merc, but I can't see why it wouldn't work with the BMW lump Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #460376 11th Dec 2017 2:33pm
holidaychicken
i had a reading of 6 on injector 3 and also fault code for same cyclinder.
Mine was the loom, as when i touched the wiring going to injector 3 the engine would cough.
i connected up live data and could watch the fuel compensation going down to zero as i gently touched the loom.
It now idles fine and even passed the MOT but it seems to be holding back when i try and get it up to motorway speeds.
i have ordered a new loom anyway to see if that cures it as the loom was very fragile.
Post #460453 12th Dec 2017 1:33am
Page 1 of 5 12345>
