![]() | Home > Technical (L322) > Heating slow? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Because it was cold yesterday - I'm sure you noticed ![]() Once running the car warmed up nice and quickly. Then found this in the Wiki: http://www.fullfatrr.com/wiki/FBH On Td6 models, additional heating reduces the heater warm-up time and is also used to maintain heater performance throughout the drive cycle. On V8 models, additional heating is only used to reduce the heater warm-up time at the beginning of the drive cycle, and only occurs if parked heating is already active when the engine starts. If I've read it right ... Your old TD6 would have always used the FBH (when required). But my TDV8 needs me to have switched the FBH on before I jump in and start the car. Going to have to test this now ![]() |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
my temp gauge never gets over a 1/4 really , from what ive read it should be at 12 o'clock , car gets hot enough though |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^ thermostat stuck open, more likely the EGR one! Yesterday I couldn't spell Engineer... Today I are one!
can it be tested then pal ?? |
I'm not sure |
ok thanks pal , I have a remap with EGR delete so its not like I need it lol |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 81 ![]() ![]() ![]() |
I har the same thing happening, I believe it was because I filled the system with water temporarily to check after repairing a leak. I found that the seals had swollen, probably because of osmosis because I filled the system with water. It would be interesting to hear if others have had experiences with slow or no heat after filming with water or Even changing Concentration of coolant (may happen when changing coolant). 2006 Supercharged |
I need to look at this valve and the EGR stat asap , see why rory doesn't get that hot |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Can you get hold of an infrared thermometer and check what your engine temperature is before you start changing things? |
erm , I very much doubt it pal |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
You can pick them up for a fiver |
oh right , wouldn't surprise me if there is an App available that does it too ?? |
https://www.ebay.co.uk/itm/UK-Non-Contact-...Sw3WxaC91q
thanks miggit |
