![]() | Home > Technical (L322) > 2011 headlight swap |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Can the lens not be swapped over. I'm assuming the lens is the same. Some folks split them open to fit halo DRL's inside so they do come apart.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You cannot swap the lenses as they are glue’d with an unusual type of glue that does not allow the “usual” heat & removal...
Mate, for the money I'd save I'd be getting the air driven disc cutter out with a 1mm disc.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
Thanks Gents
Have you tried looking for a used one. Problem with a new light on one side is it will be very noticeable. Something that would irritate me.
