![]() | Home > Technical (L322) > Cold Coolant temp, cold blower, m62 4.4 V8 Petrol |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
Strange one because normally this runs hot....
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Check that the bottom hose is getting warm - could be the thermostat is open and or the electric auxiliary cooling pump is not working (If you have one fitted not sure ) also check each side of the rad is getting warm
Thank you Sandy - no fault code on the auxilary coolant pump.
Thank you Fisha, I have the lower stat in the box ready to fit |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
+ 1 on the stuck thermostat 2006MY 4.2 SC
Opened her up and the stat wasn't stuck open but there was a lot of scale when I flushed and the stat was corroded on the outside.
