Home > My Range Rover > Pawl's 3.6 L322 TDV8
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
After joining the forum 3 wks ago we've now got our late 2006 FF RR TDV8 with 123,000 miles & started working on it's various faults.
Cleaned up, it looks OK - although there are a few bits of damaged paint to sort at some point.
As said when I joined, the info on here had given me the confidence to buy a car that was significantly down on power, smoked badly under acceleration & had various other faults - on the possibly rash assumption I probably knew the causes & could fix it without breaking the bank.
In the end I was lucky & the smoking turned out to be the well documented split inlet hose problem, but this time 1 of the right angle inlet plenum to inlet manifold hoses, not an intercooler hose. Sorted for £20, 1 hour & heavily bruised knuckles trying to get the old hose off & new hose on.
While sorting the plenum hose I also discovered 1 of the rear "straight" plenum hoses was oily, but fortunately this turned out to be just loose, not split.
Fuel consumption has improved from a worrying average 13.8mpg to at least 18mpg around town & what maybe upto 30mpg on a run. Performance is now what I expected !
An annoying rattle from the back of the rear seat area turned out to be a live shotgun cartridge bouncing about in the recess where the rear damper mtg comes into the body Shocked !
The car also has 1 of the infamous steering wheel tilt problems. As bought, the wheel was stuck in the fully up position, which was less than brilliant for comfortable driving - lol.
I've now discovered the motor works, but was dis-connected because when the car is switched on, the tilt mechanism tries to crush your legs because it can't remember where it started from.
From the fantastic info in this forum I think I might be able to fix the problem without replacing the motor - as it appears to work smoothly, but just slips when it retracts fully up. Time will tell.. ..
I'm sure I'll be back with further updates as I knock the faults off (Reversing camera, whistling windscreen, ext. door handles almost not working etc etc). Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #458821 28th Nov 2017 2:38pm
Sandyt
Good one enjoy it Thumbs Up Thumbs Up
Post #458825 28th Nov 2017 2:55pm
Paul thornton
Looks well does that and yes they certainly are a project.
I keep meaning to make a list of all the faults on mine so I can work my way through it but doubt I'd have enough ink in my pen!
Post #458833 28th Nov 2017 3:58pm
j_rov
Nice looking car there Paul. Welcome to the club! __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #458834 28th Nov 2017 4:00pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Really nice looking example you've picked up there. Cairns Blue (and that gorgeous interior!) was one of the colours I wanted myself when looking for one to buy. I can eak 33MPG out of my own 3.6 '58 TDV8 on a run down to London (running exclusively on Shell FuelSaver Diesel) so your estimates of 30 are probably right on the money.
Is that a Discovery 2 I can see parked behind it?
Post #458842 28th Nov 2017 5:39pm
Pawl
Thanks for the welcome!
Paulus1978, yes, we're pleased with it - especially since we've got rid of the horrible air "freshener" smell that we were worried was hiding something worse. Fortunately not though!
Yes, that's our well used TD5 D2 in the background - not as comfy as the RR, but very good off-road. Paul,
Post #458908 29th Nov 2017 6:13pm
gizze
My steering wheel kept doing that, then had a flat battery if left for 2-3 days.
Turns out the bluetooth and TMC module was causing a 1.2amp drain, once that was sorted and the battery up to full charge the steering wheel started working properly again. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #460412 11th Dec 2017 9:05pm
Pawl
gizze, interesting comment!
2 of the other problems, I've not mentioned are a battery that goes flat every 2 or 3 days & a Bluetooth module that appears to have a mind of it's own - lol.
Looks like there maybe a link worth investigating. I'll start by measuring the current drain if I can & then disconnect the Bluetooth module & re- check. Paul,
Post #460426 11th Dec 2017 9:58pm
gizze
For now just unplug it, and then take the optical cables out of the block and put them together to keep the MOST ring as a ring, otherwise you will get no nav etc.
You can use some small rubber hose or just tape the ends together.
The TMC modules can go a bit funny too causing a drain, as TMC is useless I would unplug that too, and do the same with the MOST cable on that. Porsche 911 (996)
Post #460737 13th Dec 2017 4:23pm
Pawl
gizze, thanks for the tips. Thumbs Up
I hadn't realised you could bypass the MOST modules so easily & still maintain the circuit. Paul,
Post #460821 14th Dec 2017 9:25am
Pawl
Front Upper Suspension Arms / Knocking Noise - Now Gone !
Finally got round to to replacing the front upper suspension arms yesterday.
The bushes at the chassis end had looked well worn for a few months and I was fairly certain they were likely to be the cause of the knock noise I was getting while putting full steering lock on at very low speed.
Changing them was easy enough - apart from the time wasted trying to remove 1 of the ball-joints which was worn enough to need replacing while I was doing the arms.
I thought I'd just be able to knock it out from above after removing the torx screws - but it wouldn't budge. I ended up using a slotting disc in the angle grinder & cutting the ball joint to pieces before the remains could be knocked out.
Anyway, all back together & no more knock noise & the suspension doesn't thump as much when going over speed bumps or pot holes - Great result Very Happy
While in the wheel arches I took out both wheel arch liners & removed a few kilos of small stones & mud that had got past the edge of the liners at the back of the wheel arches..
Surprisingly & very positively , there was no sign of rust anywhere - despite no obvious underseal on top of the paint Thumbs Up Paul,
Post #476983 27th Apr 2018 10:58pm
nearlee
Wales
Thought I recognised the name.
Are you another d2bc refugee? Remember:- amateurs built the ark
Proffesionals built the titanic
Post #476993 28th Apr 2018 7:23am
Pawl
lol - yes.
I'd almost got all of the issues with the Disco 2 under control (might regret saying that!), so I decided I'd have another Land Rover project to keep me occupied!
I see there's quite a few on here who's forum names I recognise from the d2bc forum.
All of us gluttons for punishment or slow learners do you think? Paul,
Post #477008 28th Apr 2018 10:05am
nearlee
Wales
I'm a total gluten for punishment then.
D2 to d3 to ffrr Rolling Eyes
You know you never get them fully sorted, just reduce the list Rolling with laughter Remember:- amateurs built the ark
Post #477038 28th Apr 2018 4:00pm
Pawl
Cubby Box Phone Cradle Removal
I decided to remove the OE phone cradle connector on our 2006 TDV8 as I got fed up of not being able to use the top part of the cubby box for storing a phone. With the cradle in place, the space is too narrow for even a standard Samsung Galaxy mobile. The connector by all accounts only permits very limited functionality if you can find the relevant 2G ( ! ) phone & cradle from 2006 or 2007.
It's a simple 15 min max job - involving opening the lower cubby box,
Removing the 6 small Torx screws that hold the upper part with the cradle & then lift it up & away to access the connector & associated wiring
You then just disconnect the wiring connector (it won't generate any fault codes or issues), then unscrew the 4 slightly larger screws that hold the cradle connector & remove it.
Your now left with a rectangular "hole" that if you did nothing would allow things to drop from the top part of the cubby into the bottom - Not ideal !
Simple solution was Black Duct tape cut to size over the aperture & then re-fit the top cover & re-fit the 6 screws.
Slightly neater finish achieved from above by careful cutting of a piece of dense black foam to fit the recess.
Job Done, phone now fits - or anything else you want to locate there ! Paul,
Post #492822 18th Oct 2018 6:47pm
