![]() | Home > Technical (L322) > L322 3.0Td6 03 EGR Blanked fuel consumption |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
my blank kit has just arrived , I think it for the EGR only pal , not the cooler |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Which one did you get? |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
The egr Delete is that, deletes the egr. If you want to remove the cooler/ thermostat assy you need the blank plate for the exhaust and also 2 caps for the water outlets ( I think these are 15mm) https://www.aliexpress.com/item/cheaper-sh...eLevelAB=0
the 25 quid one off ebay pal , the one with the black n yellow warning style emblem |
so your pic wayneg , shows the 2 15mm blanks , yes ?? |
yes, as I say I think they are 15mm, don't hold me to it 2007 TDV8 VSE
ok pal , now ive seen how its done I intend to remove this while I blank the EGR off |
A few in the UK don't bother with the fan so as you are up north you should try running without it once the cooler gubbins is removed. There has got to be a fuel saving and noise reduction with it gone. 2007 TDV8 VSE
ive just fitted my blanking kit for the EGR , cooler end of the pipe was already broken off |
Hi bembo449,
| Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62
I blanked mine a couple of months ago, as I had fault messages.
yes paul , the full kit , I didn't need the EGR blank discs as I removed the cooler completely , I suggest anyone with a td6 remove this part , car is smoother ,quieter , seems a little more eager and the heating has also improved quite a lot ! this was my initial reason for removing the cooler but the side effects are very welcome |
Difficult to do or straightforward?
pretty straight forward but I didn't mind working with the fan in situ Paul , long as you have / borrow a decent 1/4 drive socket set ? you will also need a T45 torx and some pipe clamps / pincer mole grips pal , the only other thing is the blanks for the cooler water pipes , I cut down a long bolt into 2 pieces , the type where the threads are only at the very end , needs to be 17mm diameter for a snug fit the jubilee clip into place |
