Home > Technical (L322) > Final resistor.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Final resistor.
Hi
I changed my resistor with meyle unit;sadly no difference.
Do i have to clear faults of previous resistor to work new one properly or no relation at all? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #460974 15th Dec 2017 9:19pm
mpirie
The FSR does not log any faults when it fails, so no errors to clear.
Replacing the FSR should allow the fan to start working again, but if it doesn't, then you either have a faulty FSR or a faulty fan motor.
I assume you have checked the relevant fuses?
Mike
Post #461013 16th Dec 2017 9:01am
Or faulty wiring - some have found burnt out wires or corrosion in or to the connector.
Also, make sure that the FSR is properly seated in its cavity, if it isn't it can quickly "blow" again. .
Post #461020 16th Dec 2017 10:40am
umitbat
Mike
My fan works,problem is it starts blowing cold after 5 minutes even at 27 and very hot at 28. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #461046 16th Dec 2017 3:28pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Currently going through similar issues - the air that comes out does not get hot though.
Is your coolant warming up _ I am pretty sure my thermostat is stuck open and will be replacing it as soon as I get some more coolant
Post #461051 16th Dec 2017 3:55pm
umitbat
I guess it does warm up because it is hot when 28 is set;some sensor or valve issue may be? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #461106 17th Dec 2017 8:19am
mpirie
So the FSR is used to control the speed of the fan.
The FSR gets very hot and uses the flow of air to keep it cool and working....hence the suggestion to make sure it''s seated in the airflow correctly.
If the fan blows cold air, then your problem lies elsewhere, such as in the heater matrix or coolant system.
Mike
Post #461123 17th Dec 2017 11:29am
umitbat
An air conditioner specialist said the air blender flap motors are faulty.
Thats why it cant mix correct temperature.
I know some cars can reset those flaps easily;like by holding two buttons starts the process.
Is there a way to reset those flaps? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #461300 18th Dec 2017 7:46pm
umitbat
Interesting Update...
Blower started to shut down itself.
When i could not find the previous unit i put the old style unit i took out from old 03 car.
Now everything works fine including fine tuning. Bow down
Fingers crossed!!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #528918 24th Sep 2019 8:39am
