![]() | Home > Technical (L322) > Couple of embarrassing questions |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Phone, search using your handset for LandRover then the pairing code is 2121 sir |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
I guess it depends on how long you are talking about.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
If its just normal lights with a normal changing period, then yes, its likely to be OK. As already said, lots of people will do effectively the same thing by sitting on the brake pedal at standstill when at lights. If its longer periods like road work lights where you may be waiting minutes, then I take it out of drive and put it in neutral.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
I think the handbook says that one should not sit with the car in drive and the brake on for extended periods, you might like to check. I always put it into neutral and the handbrake on, finding that it is not much effort, also in the dark one does not dazzle the driver behind with the brake lights that way. Only Range Rovers since 1988 |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
As regards the debate leave in drive / put in neutral, this has been discussed before. You may perhaps find this of interest:
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
Leave it in Drive. Ron B. VK2OTC
