![]() | Home > Off Topic > Nest Thermostat |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi Gang
Hey - thanks - Was it an easy fit..? Did you do it yourself.?
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
I'll shortly be installing a Honeywell Evohome system, but if my understanding is correct, isn't the Nest thermostat more suited to flats houses with only a small quantity of rooms / radiators ?
Thanks - Interesting question...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
pretty straightforwards if you understand how heating wiring works. took me longer to feed the cables than wire it up. I do it at work when we wire up new houses so its all in my head, if you are coming to it fresh it can take a bit of figuring out.
the evohome is a much more comprehensive solution, however it comes at a much higher cost.
Thanks - That makes sense.
base unit in airing cupboard, replaces timer. nest controller on wall replaces stat.
jumpin mouse Member Since: 28 Feb 2016 Location: North West Posts: 222 ![]() ![]() ![]() |
I have one and love it but I bottled the fitting and paid a bloke. It works great and is so easy to set and adjust. |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367 ![]() ![]() |
I put one in a few months ago after being re assured by the so called specialist in currys that 'YES' it will learn your routine even though I questioned if it could learn my shift pattern that covers days and nights and takes 8 weeks to repeat.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
At the other end of the price scale, i fitted one of these last week to replace dead Vokera wireless setup:
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I have 4 thermostats and 5 timer boxes. Most radiators have thermostatic values (which don't seem to work half the time). All in a listed building. I have hardwired smoke detectors and a separate alarm system that also has smoke/CO detection.
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389 ![]() ![]() |
I've got 7 Nest thermostats and 7 Nest hard wire smoke detectors.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I have Hive which I like and if the internet goes down it has stored the information previously so will still continue to work on the schedule I have set.
