Home > Maintenance & Mods (L322) > Streaks on windscreen
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
Has anyone else got this? (See pic) they are definitely not scratches and appear when the screen is wet but go away when wipers wipe the rain away.
I did have the polymer coating and think it may have come off.. any idea how I fix this? Seen a kit on ebay claiming to provide flat aero wipers for 2009 on FFRR not sure.
Please advise Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #461206 18th Dec 2017 1:48am
Worn / micro scratches due to wiper blades not being changed very often...
Replace it is the only real time cure I’m afraid sir...
Post #461208 18th Dec 2017 2:11am
there's a link in the ebay section for aero wipers, cost around £17 for the pair.. ... - .- -.
Post #461212 18th Dec 2017 8:02am
scotcruz
Thats the thing Craig.. I do replace them regularly and hardly ever have to use the wipers as I have a polymer coating which why I am confused.
I am going to try the aero ones this time.. has anyone tried them? Are they ok? Any instructions on to fit them as I understand you have to take all the plastics off and there is no going back? Current:
Past:
Post #461213 18th Dec 2017 8:21am
fisha
Even if you've changed the blades regularly, the old style blades have the branching arms / fingers which put the pressure down on the rubber unevenly, which is why you're seeing the uneven wear.
I juts bought and fitted a set of the aero wipers. Too early to judge on how good they are across all conditions. As for no going back, if you're careful you can remove the plastic without breaking it ... but you need to be very careful when doing it. The plastic is quite brittle.
Fitting was easy ... although the blades too a fair bit of force to clip in. It was very snug fit for mine. V8 or else ...
Post #461215 18th Dec 2017 8:49am
scotcruz
Yeah.. deffo worth a try I think..
Can you share a link to the item fisha?
Cheers Current:
Past:
Post #461216 18th Dec 2017 9:19am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I took Craig's post as meaning to replace the screen. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #461224 18th Dec 2017 10:14am
scotcruz
Yikes !!!!! Current:
Past:
Post #461225 18th Dec 2017 10:17am
fisha
The wiper blades were the ones listed in this thread...
http://www.fullfatrr.com/forum/topic45280.html V8 or else ...
Post #461243 18th Dec 2017 12:39pm
scotcruz
Superb... ordered and will report back.
Regards Current:
Past:
Post #461244 18th Dec 2017 12:44pm
scotcruz
Ok guys.. got my wipers delivered and fitted them fairly easily.. couldnt save the plastic it has said there for so many years.
Anyhow tried them out yesterday and while the driver side is fine. They seem to miss a section out on the passenger side which has dampened the excitement a little bit.
I read on another thread here that someone had the same issue and wondering how it can be resolved?
Many thank (and Festive Greetings to one and all) Current:
Past:
Post #462134 25th Dec 2017 9:57am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I think they gave the wiper arm a tweek (twist) to get the blade to sit squarer to the screen.
Here it is
http://www.fullfatrr.com/forum/topic34618....p;start=15
Post near the bottom 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #462178 25th Dec 2017 7:59pm
I think we used to be able to be adjust the angle on the wiper where It bolts on. I think they may have changed that on the later arms tho, I can’t remember. There is nothing that can't be fixed with a hammer😜😜
Post #462188 25th Dec 2017 11:30pm
scotcruz
These are the non hook ones and all the thread I have read do not suggest the wiper arm needs a mod. I think it may be a bad wiper.. will report back. Current:
Past:
Post #462396 27th Dec 2017 11:55pm
