Home > Maintenance & Mods (L322) > Won’t open
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Won’t open
Oh no not so close to Christmas my drivers opens from the inside but not from the outside has anyone got ideas please thanks in advance Big Cry
Post #461266 18th Dec 2017 4:37pm
outer cable broken? ... - .- -.
Post #461268 18th Dec 2017 4:47pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
as above , assuming the handle retracts when you pull on it ?
Post #461269 18th Dec 2017 4:55pm
Simran0211
The handle does pull back is it a pig 🐷 if a job to do
Post #461345 18th Dec 2017 10:58pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
The outer driver's door cable on mine went recently. Symptoms exactly the same as yours. Took my brother and I about 1.5 hours to refit a new cable (£27 on Eb*y). Most fiddly bits are:
* Reconnecting the inner door handle cable (hold the inner door handle open whilst re-fitting).
* Getting the stub of the broken cable out of it's notch.
* Refitting the window trim where it connects to the door panel (put the trim in place first, then fit door panel).
* Careful with the the door airbag - you'll have to unbolt it and let it dangle from it's cable - no sharp knocks!
* Be sure to fit the new cable behind the inner door strut or it will prevent the window from going down (ask me how I know this!).
Given that the local LR dealer wanted a minimum of £140 (1 hour labour) + parts costs to fit a new cable, it was worth doing ourselves.
You'll need a set of Torx screwdrivers and nimble fingers.
Post #461347 18th Dec 2017 11:19pm
Simran0211
Wonderful thanks for your help now to order it 👍
Post #461350 18th Dec 2017 11:49pm
