![]() | Home > Technical (L322) > Iidtool key programming |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
so its not clicking as you insert the key pal ? |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 ![]() ![]() ![]() |
No, if you put in the old key you hear it disengage the steering lock but the new one
the car isn't recognising the new key then ( obviously ) there must be a way of opening comms to allow for the the pairing of new keys though |
Hi
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Does the key work in the door lock? 2015 4.4 AB
Yes it locks and unlocks the doors |
Just trying to rule out the phyiscal key 2015 4.4 AB
Just trying to rule out the phyiscal key . Which iid tool do you have ? 2015 4.4 AB
Have you tried putting the new key into the ignition then putting the coded key as close as you can to the ignition to trick the ignition into turning off the steering lock, then turn the uncoded key, then remove the coded key are voila your ignition is on and your uncoded key is in the ignition |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766 ![]() ![]() ![]() |
Wish I lived near you!
I have a 2017 BT iidtool from Dan. The coding part is easy it's just that you need to turn the key and I don't know
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
And what if you have a 2010+ with push button start ? |
For push button start its incredibly easy. Takes about 30 seconds from start to finish with my IID tool. I programmed a new shape ( smaller ) key. The original key isnt even used. I now have a spare at home and in the office. Proberbly lose the one im using when im out now !!!! 2015 4.4 AB
