Home > Technical (L322) > Help with rear brake part numbers.
dognero
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Hi I have a 3.6 TDv8 Vogue SE born on the 11/12/2008
the rear passenger side caliper has stuck on causing the pad to disappear and the disc badly scored.
I am after help locating the part numbers for the discs, pads, calipers, and pins also the sensor wire and anything else I might need to replace. I am probably going to redo both sides with new.
Any recommendations on parts, suppliers would be great. Also what parts to avoid.
Thanks for any help.
Andy
Ps Are these ok https://www.ebay.co.uk/itm/RANGE-ROVER-MK3...1438.l2649
Post #461395 19th Dec 2017 11:11am
ask dan on the duckworths site sponsor section Thumbs Up ... - .- -.
Post #461396 19th Dec 2017 11:13am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461400 19th Dec 2017 11:21am
dolph34
Hope the above helps , please double check these parts fit your machine., these were for my 2007 3.6 VSE about 2 /3 moinths ago. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461401 19th Dec 2017 11:23am
