![]() | Home > Technical (L322) > TD6 Intermittent judder / injector fault |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
A leak off test might help to confirm things:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If you do end up taking it out and it's a pain i believe this is the tool to help remove it.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
^ I'd try my method first, it's a lot cheaper! Yesterday I couldn't spell Engineer... Today I are one!
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
This is the tool you want to pull those injectors.. it screws on to the outer and inner thread for security and less chance of damaging anything.. it simply screws onto a slide hammer
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
When you are done reset the adaptive values via your diagnostics then give it a chance to settle down before any further test.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Wayneg, is that in the calibration section of the IID tool? |
Not sure about IID Tool, I use BMW IPNA. There is just one button to hit " Reset Adaptive Values". I presume it's not necessary as the car will adapt on its own in time, but this gives it a reset. 2007 TDV8 VSE
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
I had similar symptoms. My car is now on 210k miles
Beemergriff,
My shiney new loom has arrived and I’m £166 worse off but mine is definitely duff, it’s my turbo actuator that is in need of TLC.. |
Well....
Good Job! |
Cheers mate. Hope you manage to get somewhere with yours.
Always a good feeling when research planning and effort comes good. |
