Home > Technical (L322) > Well that's not gone well
wack61
Bought a L322 with a goosed TD6 , bought a M57 engine out of a X5 , got it fitted and
Initially it had a lot of crankcase pressure but changing the breather cured most of it but it had a dink dink dink that got much louder under load
So I appear to have replaced a knackered engine with a really knackered one
Post #459898 6th Dec 2017 10:01pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Big Cry 2009 Stornoway Grey Vogue TDV8
Post #459900 6th Dec 2017 10:11pm
holidaychicken
Plug it and get your codes read, you never know it might not be terminal, but then again..
Censored Censored
Post #459909 7th Dec 2017 1:26am
wack61
No waning lights on , revs right up to the red line, on tickover it doesn't sound too bad , thing is if you look on eBay there's dozens for sale but few sold listings so it could have stood with no oil in for years
The seller is as surprised as me, has over 4000 feedback on eBay , it was taken out by undoing every nut, water pipe and loom connector so I didn't think for a minute it wasn't good
We're discussing what to do about it
Post #459911 7th Dec 2017 7:02am
Weegie
Sounds very much like the top end. Have you had the cam covers off to look at it? John
GAP iiD BT-Sold
Post #459913 7th Dec 2017 8:39am
wack61
I've used the mechanic that fitted it for over 10 years, he has a lot of experience with diesel engines, he's telling me because it's running on 6 cylinders and revs to the red line he thinks it's the little end because it's too loud to be a stuck tappet problem.
I can only go on what he's saying, the old engine smoked like a steam train, this one still smokes but he thinks it's all in the exhaust.
he's saying he could spend another £100 getting the rocker cover off for a look to see what the problem is but it may still be terminal
The guy I got the engine from has over 4000 100%+ on ebay and is as Censored off as me about it because he thought it was fine as he collected the car and it drove in OK , the problem may be related to how long it's been standing with no oil in it ready to be sold.
He is going to give me my money back but that doesn't help with the labour costs
Post #459931 7th Dec 2017 12:13pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Give money back for part is ok, but money for work? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + C220CDI Convertible 2021
Post #459959 7th Dec 2017 5:35pm
wack61
Money for labour , fat chance of that , at least he's holding his hands up over the engine.
Post #459964 7th Dec 2017 6:05pm
wack61
I found a M57 forum somewhere in Europe on faceache , they're telling me to get the injectors tested as it could be an injector problem , I've never heard an engine sound like that without it being something major causing it , could it knock that loudly from an injector issue
Post #460132 9th Dec 2017 5:33pm
miggit
The only time I've ever herd anything like that was under extreme load on a very hot engine... so it could be an injector running weak... hopefully you still have 6 spares! Yesterday I couldn't spell Engineer... Today I are one!
Post #460143 9th Dec 2017 6:28pm
wack61
Spares of everything, 2 complete engines, I think it needs further investigation before I spend £600 on another engine plus the same on fitting .
Post #460144 9th Dec 2017 6:45pm
AnotherMutley
When the injector o rings went in my D2 TD5 it sounded very similar.
Understand the Discovery was an LR lump and the L322 is a BMW unit.
What does the oil smell like in the replacement engine?
Post #460658 12th Dec 2017 10:12pm
wack61
Picked another engine up today only I've seen this one running and I've bought it with the injectors still in it , decided it was going to be cheaper in the long run just to write it off and start again rather than try chasing faults down at £££ an hour
Post #460670 12th Dec 2017 11:29pm
wack61
New engine fitted , got the call today, come and get it, running fine
got to decide whether I can be bothered to make the 150 mile round trip to take the old engine back or just sell the working bits on ebay
Post #461456 19th Dec 2017 7:15pm
miggit
The main thing is you're back on the road Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #461465 19th Dec 2017 8:32pm
