![]() | Home > Technical (L322) > Drive shaft replacement |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1498 ![]() ![]() |
Yes, diy-able job. But you'll need a couple of things.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I did mine on my drive I think it was winter, the hardest part I found was actually removing the cv joint off the end of the shaft, it may have been easier to remove the whole driveshaft from the diff. You could always change the complete driveshaft with a nice Delphi one. I did work out that if I removed the cv boot and held the joint in line with the shaft and tapped the cv joint next to where the shaft came through it popped off but only when I held it inline.
I couldn't get the shaft to slide through easily enough until the threads could be grabbed by the hub nut ... that was my issue. Seemed to come out just fine, but it just was not for going back in easily. ITs a pity the inner of the shaft isn't threaded such that you can grab it towards you through the hub. V8 or else ... |
From memory I think I offered it up a few times and cleaned the internal spline on the hub and made sure the spline on the shaft was burr free and I lubricated it well. An internal thread would help for sure.
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
Thanks to everybody for your replies and advice. As the drive shafts are (I think) the original ones it makes no sense just swapping one CV joint - Though it's probably the outer CV that's crunching, I haven't even gone under the car yet to check So, I will change the whole shaft with both CVs, probably GKN, that seem to be available for around £200.
