Home > Technical (L322) > Is the 3.6 suppose to run hot?
rar110
The temp gauge on the L322 3.6 always stands to attention when running. I’ve only seen it move right on a really hot day when driving on a soft sandy beach in low range.
Under the bonnet always feels hot, even more so when the motor works hard and the fans are at full bore. On a hot day, day over 30 degrees, the radiator fans are working hard.
Is this normal? Ive never had a problem. I should hook up the IID tool to get some real data I suppose.
Advice would be appreciated. ______________________________
Post #461493 20th Dec 2017 9:38am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I'd say it was just your hot climate. As you say, you have not had a problem. Maybe look into that waterless coolant if it's an issue. Engines run cooler as it is better at removing heat because it doesn't vaporise. Also virtually no pressure builds up so less strain on components. Plenty of info on the web about it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #461500 20th Dec 2017 10:26am
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Even after a 130 mile drive down to London, my needle remains resolutely back in the center of the gauge once she's up to temperature. It stays there too even if I've just taken a short trip into town. It seems that's where it's mean to be on the gauge during normal operation
Post #461509 20th Dec 2017 2:07pm
in our warmer months i could feel the heat of the engine as i passed by.. my needle stays vertical all the time.. ... - .- -.
Post #461529 20th Dec 2017 3:14pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
twin turbo isn't it ? will generate some serious heat Id expect
Post #461533 20th Dec 2017 3:40pm
rar110
Yep temp gauge rarely moves from the verticle position once warmed up. Other than on that beach run. ______________________________
Post #461568 20th Dec 2017 9:38pm
rar110
Yesterday the temps were well under 30 degrees, so the top of the bonnet was cool. However the driver side passenger side guard was warm. Could this be the fuel cooler transferring heat?
Thanks ______________________________
Post #461711 21st Dec 2017 8:52pm
Bluegreygreen Rangie
Australia
These modern engines types (including the 3.6) are designed to run hotter than older engines... and as some one said with the turbos and coolers etc it will get very hot under the engine bay , I do notice allot of heat is generated myself
In saying that i have never seen my gauge move past the standing straight up position.. if your concerned you need an id tool or other way of confirming the actual coolant temps
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #461814 22nd Dec 2017 2:25pm
