![]() | Home > Technical (L322) > 1st Post - Heater always Hot |
colinwebster Member Since: 19 Dec 2017 Location: Devon Posts: 43 ![]() ![]() ![]() |
Hi all, my first post after joining.
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341 ![]() ![]() ![]() |
Opposite problem to mine - have you read the bleed threads on these? |
Yes Ive studied them all, most of them relate to the heater being cool if there is an air lock though, mine is the other way.. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Thanks it’s not the centre vent I’m having issues with it’s the heater in general. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3275 ![]() ![]() ![]() |
Have you got the air con button pressed in? It's the one with the snowflake and has to be illuminated to have the air con working. Otherwise you just have the heater function.
It could be the bowden cable that has come loose on the dial nino said - easy to pull the vent out to check, takes under 5 minutes to rule it out
(bit of a wiggle to get it back in) |
Before you fit the thermostat seriously consider this mod http://www.fullfatrr.com/forum/topic39362....thermostat |
Sincerely - Thanks to all for your replies - in order to avoid wasting anyones time, Id like to clarify further.
The centre vent is not connected to your issue IMO as, from what you say, it appears to be functioning properly. Have you checked that the AC is activated as per my post above? John
Yes, The air con switch makes no difference.
How about seeing if an air con test and recharge works? John
Again, thanks for you input, I think even if the aircon didn't work, IE no gas, the heater output would still blow cooler that it does. we are at 5 degrees c here in the UK
